private message
yves mouton
Been liked: 741 times
private message
Post by yves mouton »
Hello,
I got a new pm and i cant open it,
this is what i get on the screen ( You have 1 private message currently on hold because of full folder.
Release all on-hold messages… they will be re-sorted into the appropriate folder if enough space is made available).
Strange because i clean up my folders and i still cant read my message
Best regards Yves.
Has liked: 1475 times
Been liked: 1674 times
Re: private message
Do you have rules set up to redirect PMs ?
It may be that a sub folder is full, not your Inbox. Go into each folder and you should find the one which is full.
Also, you need to click on the test where it says "Release all on hold messages". It's in bold but not very obvious. They don't get released automatically when there is room.
If an Admin is reading this, it would be great if the limits on the number of PMs and folders was raised, as there is no easy way to archive old conversations.
yves mouton
Re: private message
Hello Adrian,
every folder is clean, but where can i find the button
to releas the onhold private pb?
regards Yves
Been liked: 3681 times
Re: private message
We have increase the limited on private messages from 50 to 100 and increased the number of folders from 4 to 10. Hope this solves the problem.
Re: private message
Yves, where you see the message you included in your first post, click on the part that says "Release all on-hold messages".
Many thanks for increasing the quotas :-)
Adrian
yves mouton
Re: private message
Hello,
Thanks for the help, it works ok now.
Regards Yves
