FOTUBA 6EX JOYSTICK
- Has liked: 4 times
- Been liked: 15 times
FOTUBA 6EX JOYSTICK
I know you can change the l/h joystick from ratchet to smooth feel by changing the spring which bears on the wheel inside, but can you make the joystick self centreing like the r/h one by fitting the missing parts? While I was fitting the smooth feel spring both sides looked like it was possible.
Graham
- Been liked: 19 times
Hello Grayham
As Roland says you need to by the return spring for that set. If you are going to the open day i will bring one down for you and i will fit it for you.
Lee
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
- Been liked: 177 times
