Mick's Panther A
michael hilton
Has liked: 1564 times
Been liked: 835 times
Re: Mick's Panther A
Post by michael hilton »
Hello everyone, with the inclement weather, I have secured a short term lease on the third bedroom workshop. A full 'wheel' production run now in progress. First mistake, I fitted wheel studs to both the front and rear....wrong, resulting in a shortage of studs......'Araldite' is a sod to release....Oh, and make sure you vote :) Mick
Has liked: 1420 times
Been liked: 1595 times
Heat breaks epoxy glue down - a soldering iron would probably do for the rivets - and acetone cleans up the mess, but make sure you do it in a well ventilated area !!
Has liked: 2267 times
Been liked: 7152 times
Hi Mick, you could order some more studs from Armorpax :D regards Phil.
michael hilton
Thank you Adrian and Phil, I think it's the easy route...just buy some more studs.....Mick :oops:
michael hilton
Wheels to go....I side stepped the 'stud' problem by fitting hex head bolts to the hub caps, they look rather nice. I have jacked the old girl up on blocks to fit the wheels, and ordered the 'Option' packs, all is well, that ends well.....Mick :D
Wheels upon wheels upon wheels....
michael hilton
With the weather booked fine for the weekend, I made an early start laying down paint....I also started the washing machine..... :roll: After sixty years of marriage (4th June 2017 our Diamond Wedding Anniversary) I know my place.... :wink: ....Mick
Up on blocks. Painting by numbers....
400ML Rattle cans, 7.95 each. plus 10.00 Ship and Handle.
I use Epic Militaria Army Paint Industrial. Located in Wales. They are on line.
michael hilton
Best wishes to everyone attending Tankfest enjoy the weekend....post lots of photographs...... Kwik-Fit man arrived couple of days ago. Using my patented M3 Super Strength Double Sided Tape to fit the tyres :)
michael hilton
Hello everyone, went for it this morning fitting the wheels. I had already made up the drive sprocket consequently I was unable to locate first double wheel set. Removed the outer sprocket ring for access....all is well....Mick
P S enjoying the Tankfest photos.....
michael hilton
Made a start on the turret....nice easy fit. On the PhotoBucket issue....unable to gain access. Have not posted on their site for quite a while. Fortunately, all my early build photos are saved on my external hard drive.....I now load photographs directly onto the Forum....Mick
Oh, and I also did the washing....my life....
michael hilton
Question, I have tried to fit the Pivot Bolt (CH0439) through the part (CH2409) Mantlet and into the Inner Mantlet. The bolt is a good fit into part (CH0438) Inner Mantlet but will not slide through the Mantlet. Now, it seems to me I need to remove some of the threaded area, Ok..Problem solved with a fine round file, job done....Mick
Good fit in the Inner Mantlet.
Pivot Bolt will not side through the 'threaded' part of the Mantlet. Then screw in...
ian.cameron
Been liked: 1 time
Post by ian.cameron »
Hello Mick
I dry built mine (No 27) quite quick and found the same issue. I don't have the luxury of pillar drills, lathes etc., mine was going to be built straight out of the box, otherwise I am sure I could have drilled out and tapped to the correct size. Luckily I had a construction project near to Honiton and Mark and Jill re-worked it for me.
You are correct the inner mantlet requires drilling and tapping to the size of the bolt thread supplied, just a minor glitch in the CNC programming that was overlooked. Hope this helps.
Ian Cameron CMIOSH (Ret'd RAF Armourer)
michael hilton
Thank you for your reply Ian, All's well, I carefully ran a smooth round file through until the bolt entered. Then used a thread cutter to clean the threads out. Thanks again....Mick
michael hilton
Hello again merry men, Having resolved the Inner Mantlet/Pivot Bolt location problem. I need to ask this question before going further.
I am now working on the Outer Mantlet to Inner Mantlet area. The instructions read as follows......'radius corners ( of Outer Mantlet) with a file to allow Outer Mantlet to fully position' inside the Inner Mantlet. I seem to be removing lots of metal, I have rounded the edges of the Outer Mantlet however, I am still about 2 millimetres away from being able to locate the Pivot Bolt and rotate the Outer Mantlet. Do I keep going with the file, or have I again missed something......Mick
I guess I need to file away 2m of the curve to get free movement
Been liked: 3486 times
Hi Mick
This reply is for all Panther builders really
The inner mantlet does not require drilling and tapping to fit the pivot bolts. There is just a tiny bit of interference caused by a burr thrown up during the threading of the boltsa and tapping of the holes. It takes only seconds to resolve with a file. This is all we did to the set that were returned to us.
It is, however, necessary to remove quite a lot of material with the file, to get the outer mantlet to sit down in place and pivot. A full radius is required to get the clearance.
michael hilton
Thank you Mark, my hero :) .....the pivot bolt was an easy fit after work with the round file. I was just concerned that I had missed something.....didn't want the whole Mantlet to end up on the garage floor as filings..... :D
