Yves Panther A update
yves mouton
Been liked: 741 times
Post by yves mouton »
Hello,
Pictures coming soon
Regards Yves
yves mouton
Re: Yves panther update
Hello,
Here are the first pictures of my panther
Tomorrow new pictures.
Regards Yves
Steen Vøler
Has liked: 62 times
Been liked: 500 times
Post by Steen Vøler »
Hi Yves,
Its always good to start up a new build project :)
Happy building to you and look forward to see more pictures
cheers
Steen
yves mouton
Hello,
Here are some new pictures of the work on my panther.
Did a modefication on the gear, spacer rings for turret rotation, i drill extra holes
to put the rings together, so if i wanted to loose the turret i have only to unscrew the 6 wingnuts.
I also countersink the bolt in the rear deck.
I put the turret parts in primer and put them back together.
Also started on the turret roof and copula.
Regards Yves
Steve Norris
Has liked: 8 times
Been liked: 701 times
Post by Steve Norris »
Hi Yves
Looking good, the turret ring mod sounds a good idea
Has liked: 161 times
Been liked: 831 times
Hi Yves,
She's looking great. Can't wait to get started on mine! Following your build with great interest!
yves mouton
Thanks you guys
8) 8) 8) 8)
Regards Yves
Maarten Schutjes
Been liked: 3 times
Post by Maarten Schutjes »
Impressive work Yves
Has liked: 2282 times
Been liked: 7196 times
What a gorgeous little mill! You will be in the sh.t if she's sees her washing line being used as an outdoor spraying booth.
Good idea with the wing nuts , three would have been enough :D regards Phil.
yves mouton
Hi,
Thanks for the good comments on my buid, Phil the washing line is not from my wife,but
from my mother so i dont be in trouble using that as a spray boot :D :D :D :D :D
Best regards Yves
nice to see you back on the forum yves, pleased with your long awaited panther kit, regards simon.
Been liked: 3699 times
Hi all
The standard kit design of the new turret bearing on the new Panther is the same as that used on Tiger 131. The bolts go in from underneath , through the spacers, bearing ring and gear and a nut is fitted on top. To fit the turret simply lower it onto the projecting bolts and secure with the wing nuts. There are cut outs on the underside of the floor to clear the first nuts.
Paul Wills
Has liked: 646 times
Been liked: 143 times
Post by Paul Wills »
Hi Yves,
Its great to see you busy building your Panther, I am looking forward to see your progress.
Paul. :wink:
yves mouton
hello,
A few pictures, work on the scope covers for the copula,
with my mill machine.
Regards Yves
Steve Norris
Has liked: 8 times
Yves
Very nice, I will have to use a file on mine
