This is my first post so be gental with your responses !!!,
I recently purchased a Mid Tiger 1 part built complete with all options including " The Gun " with unfitted upgrade parts, so i decided to fit the upgrade to it. Not an easy task due too poorly meshing gears and binding hammer but with a little machining work on the gears and spacers on the hammer mech. all now runs nice and smooth.
I carried out a test firing and all went well until it came to removing the spent blank, what a difficult job it proved to be, i had put a small amount of grease on the blank as recommended. The blank was a very tight fit when installed.I was also supprised buy how much mess was left behind after.
Can anyone suggest better blanks or lubricants which may help ?
Tony
