Hi Chris
Thanks for the info. Just finished the red oxide on the back plates will have look at the gap.
Yes, your quite right no space for the domed nuts, haven't looked at the rear tray before as need to look at the rest of the winch kit first page 23.
Studs fitted to hubs instead of set screws. Gearbox run in gently, axles, couplings and hubs all greased. Replaced where possible a lot of hex and cheese head fasteners with stainless button heads, which looks a bit more in keeping. Made a couple rubber seals to close up the big holes at the ends of the steering axle to keep dirt out. Didn't fit the diff half shaft springs that are supposed to keep pressure on the steering hubs. There's not enough movement in the shafts for them to become disconnected.
