Hi Adrian
You will get the three clicks through the speakers even if the amp output is blown.
Help Please - Sound System
- Been liked: 3688 times
- Has liked: 605 times
- Been liked: 147 times
Re: Help Please - Sound System
Adrian, re use of the button, yes press and hold on power up to enter program mode. It's the single press with everything on that doesn't seem to do anything..... No green led, no clicks etc.
On the cent I believe tbs5
Hi Mark....your spanners are always welcome too! When you say "amp output blown", is there an onboard fuse or is it futou as they say down here?
Kevin
Kevin
- Has liked: 1478 times
- Been liked: 1681 times
Oh, didn't know that
Hi Kevin
Its a return to us job, I'm afraid. Probably repairable.
Ok Mark, many thanks.
I'll drop you an email once I've sent the unit to you - need to get past this weeks show first.
Best
Kevin
Best
Kevin
