Help Please - Sound System
Been liked: 3688 times
Re: Help Please - Sound System
Hi Adrian
You will get the three clicks through the speakers even if the amp output is blown.
Kevin Hunter
Has liked: 605 times
Been liked: 147 times
Post by Kevin Hunter »
Adrian, re use of the button, yes press and hold on power up to enter program mode. It's the single press with everything on that doesn't seem to do anything..... No green led, no clicks etc.
On the cent I believe tbs5
Hi Mark....your spanners are always welcome too! When you say "amp output blown", is there an onboard fuse or is it futou as they say down here?
Kevin
Has liked: 1478 times
Been liked: 1681 times
Oh, didn't know that :?
Hi Kevin
Its a return to us job, I'm afraid. Probably repairable.
Kevin Hunter
Ok Mark, many thanks.
I'll drop you an email once I've sent the unit to you - need to get past this weeks show first.
Best
Kevin
