Tiger 1 (Early Variant) 2004 #98 build
Re: Tiger 1 (Early Variant) 2004 #98 build
I know what you mean about 40Mhz but I've got soo much invested in FM and not a lot of cash to throw around.
I'm half waiting to see if the wi-fi remote control works (or not). If it does work then maybe a USB control sticks with cheap pad (for soft button and camera) would make more sense. Presumably for tanks any slight extra latency wouldn't matter so much. I struggle to remember what all the switches and knobs on RC remotes do and my Dad is worse.
Currently I'm having a mini breakdown trying to decide what speakers to buy.
Sam
Sam
- Has liked: 1492 times
- Been liked: 1699 times
The Tannoy EFX/SFX ones Armortek supply are very good.
They're small but powerful and give a good amount of base from a small case.
Adrian
Adrian
Thanks. It looks like they fit at the back on the sides so I could keep the batteries in their standard position.
- Has liked: 264 times
- Been liked: 196 times
I have some spare that I can part with, if you can let me know before this evening I can bring a pair to Tank Fest.
I could be seeing artifacts but the spectrum of 131 engine noise looks like it has a lot of energy at 80 and 200Hz.
For the flak88 firing a lot of energy is under 100Hz!?
The 100mm diam speakers cut off at about 150Hz.
Has anyone got a good enough hi-fi to listen to files with or without the 150Hz information?
Just to be clear, I have no idea what I'm doing
Sam
Sam
80Hz for the engine implies 4800RPM!? Could that be roughly right?
Doesn't it depend on the number of cylinders and how many cylinders fire per crankshaft revolution ?
I seriously doubt anyone has revved a Tiger engine to 4800RPM since the fifties
OK. I'm just digging a deeper hole for myself but... 12 cylinders at 2 revs per bang giving 80Hz comes out at 800RPM? https://en.wikipedia.org/wiki/Maybach_HL230 says max torque was at 2000RPM so maybe 800RPM is roughly right!?
- Been liked: 19 times
Stage 1 delivered to the South for the electronics expert.
Stage 2 in the North started in a hull mock up.
Don't know how others fix the handles to the engine cover but I decided to braze them in place. Shown before being ground flat.
- Paul Wills
- Has liked: 646 times
- Been liked: 143 times
Hi Graham,
I think the instructions say to glue the the handles in place, but brazing them in place works even better
Paul.
Paul.
What glue do folks use to stick the turret bearing brass half rings to the steel deck, please? I suppose I could braze it
- Been liked: 3 times
I have not fixed them, and they seem happy, the turret keeps them secured.
Thinking about another layout now I've seen sense and I'm getting the standard speakers.
Electronics being near the switches (under the front hatch) and camera having short route to front seem good. Downside is longer power lines to fuses and relay? Also not sure what RF the power controllers have.
I should just get on with it now though
