Tiger 1 turret question
andyquirot
Been liked: 33 times
Post by andyquirot »
Hi all
Dose the turret just sit on the brass ring or should there be some kind of bearings.
Because mine is very tight.
I am thinking about drilling some small shallow holes and putting some steel ball to act as a bearings.
Regards Andy Quirot
Has liked: 1485 times
Been liked: 1695 times
Re: Tiger 1 turret question
It just sits on the brass ring.
Is yours in two halves ? That type were dashed hard to get circular.
The current ones are machined from round stock, so no roundness issues.
Try marking around the brass ring with a permanent marker, then install the turret and move it around. That should show you the worst of the sticking points.
andyquirot
Hi there
Thanks for that i will try that now.
Yes 2 brass halfs needed lots of clamps and string to get it to follow the contour of the deck.
Thanks again
Chang
Has liked: 16568 times
Been liked: 487 times
Post by Chang »
andyquirot wrote:Hi all
Regards Andy Quirot
Hi Andy,
Read this article maybe helpful on this issue. :idea:
http://www.armortek.co.uk/Forum3b/viewtopic.php?t=3936
Kind regards,
Lerh Chang :D
Edward Earp, Jr.
Been liked: 1 time
Post by Edward Earp, Jr. »
HANS-PETER QUAMBUSCH IN GERMANY MANUFCTURES WHAT YOU NEED. BEAUTIFULLY MADE BEARINGS FOR THE TURRENT. I BOUGHT 12 FOR MY KING TIGER. HE DOES NOT GIVE THEM AWAY....IN FACT HE IS RATHER PROUD OF THEM AS HE SHOULD BE. COST ME $165.55 INCLUDING POSTAGE.
USING THESE BEARINGS ELIMINATES ALL WORK FOR YOUR TURRENT MOTOR !!!
ED EARP, JR. edearpjr@austin.rr.com
