Wobbly wheels?
Ian Porter
Wobbly wheels?
Post by Ian Porter »
Hello All.
I'm hoping that I can tap into the vast amount of knowledge on this forum. I'm doing a simultaneous build of both the limber and 25 pounder. I've assembled the wheels as per the drawings but when they are mounted on the axles, there is quite a lot of side play. However, give them a spin and the wheels run freely & true with no visible run out. Is this something that anybody else has encountered or have I misinterpreted something?
Many thanks.
Ian
Been liked: 3699 times
Re: Wobbly wheels?
Hi Ian
Can you either send us picture, or post a picture here, showing your assembly.
thanks
Ian Porter
Re: Wobbly wheels?
Thanks Mark,
Will see to it over the weekend.
Ian
Ian Porter
Re: Wobbly wheels?
Hi Mark
A few photos as requested. I also have a short video clip of the problem, but I am unable to upload it. Any suggestions, no matter how they might reflect on my competence, are welcome.
BTW, Axle EJ0105 - how long should the tapped stub be?
Many thanks,
Ian
Dave Nadin
Been liked: 3 times
Re: Wobbly wheels?
Post by Dave Nadin »
Hi Ian, I am building the 25pdr kit and also have the wobbly wheel problum, I found that the bearing fit on the axle stub is a slighty lose fit. I have used the remains of a 0.15 feeler gauge blade, to make a shim which fitted between bearing centre & stub akle. Provided that the shim is fitted in the same postion on both sides of the axle, there is no adverse effect on the wheel alinement.
Happy building Dave :P
IAN HINKS
Re: Wobbly wheels?
Post by IAN HINKS »
On mine the retaining plate sits on top of the bearing outer race. I see from your photos yours seems to go over the bearing. My wheels wobble very slightly but I put it down to play in the bearing and fit to the axle. My axle measures at 0.470" and the bearing inner race measures at 0.472", so a 0.002" clearance. I'll try to measure the amount of wobble on mine and let you know for comparison. But Mark should have more information on the clearances and retainer when he sees your photos.
Gunner.
IAN HINKS
Re: Wobbly wheels?
Post by IAN HINKS »
Boy do I feel an idiot, just noticed that you haven't got the retaining plate fitted in your photos, still I hope the measurements I took give you a comparison. Must look closer before commenting.
Gunner.
Ian Porter
Re: Wobbly wheels?
Thanks for the info gents. I'm a bit tied up for the rest of the week, but will compare with your measurements at the weekend.
Gunner, nice to know that I'm not the only one who makes similar errors. I put it down to enthusiasm.
Ian
