Good evening Ray. I have riveted as much as I can so far of the top and bottom pieces as I can. I have not peened the rivets on the inside properly as they don't really show, my main target was to get them in tight and secure so they won't fall out or rattle!
The interior colour of the tank is white as in the originals, plus it should make seeing what is going on inside easier when fitting motion packs, etc. The non visible interior of the Hull Sides is going to be grey primer to try and keep things a little less dark when fitting out later.
I am going to Bovington tomorrow with some questions now that I am actually building the model. The first thing is going to be to try work out the actual colour of the inside of the track horns, and also where the track runs, top and bottom. I am going to use Red Oxide Primer initially and then go from there. My main thing has been to get the steel covered so when the weather gets damper it won't rust. The second thing is that the Fuel Tank appears to bolted together in places and whilst I want to rivet as much of the tank as possible, bolts will make it easier to do.
I will check the forum before we leave at 9.00am (GMT
![Smile :)](./images/smilies/icon_smile.gif)
) just in case there are any requests for information!
