Rubber to metal glue
- Been liked: 8 times
Hi Chaps.
Some of my tyres have come loose from the wheels on my Firefly.What might be the best glue to use and can you say where I might buy it from.
Duncan
Duncan
- Has liked: 8 times
- Been liked: 4 times
Re: Rubber to metal glue
Hi Duncan,
Did you use the Loctite 410, I used it on myT34/85. From Bearing Shop sales@bearingshopuk.co.uk
Walter.
Walter.
Hi Walter
Ta for the reply. I didn't make the tank so wasn't sure what the previous owner used.I'll try your recomendation.
Dunc
Dunc
- Been liked: 15 times
Duncan
You want loctite 480
lee
lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
- Been liked: 603 times
Hello,
Yes thats the one nr 480 Loctite,
it's a black substance, once the bottle is open you can use it for
maybe 6 weeks, than the glue becomes hard in the bottle.
I use that for my tiger roadwheels and they donth come of.
best regards Yves
best regards Yves
- Has liked: 1024 times
- Been liked: 2094 times
Loctite 480 is very effective but not cheap. A while back, we discussed an alternative UK source which is much cheaper:
http://www.shop4glue.com/about-1-w.asp
I haven't exhausted my supplies of various Loctite products yet but when I do, I'll be giving these folk a trial run.
Hope that helps.
Hope that helps.
- Has liked: 218 times
- Been liked: 183 times
Hi Guys
I have used this on my Comet and it seems to be the same as the
Loctite 480.
http://www.shop4glue.com/50g-flexy-cyan ... e-87-p.asp
The delivery was a bit slow but they sent the goods and ask for payment after they arrived.
They normally are at the midland ME shoe in Warwick and that starts on the 16th.
Loctite 480.
Thanks chaps,
Might give the FlexyCyano a go. Let you know how I get on.
Dunc
Dunc
- Been liked: 2 times
I just used Araldite 2 part epoxy. Make sure it's the 24 hour one and not 5 mins.
Robin
Robin
- Has liked: 10 times
- Been liked: 223 times
I like Robin have used good quality 24 hr Araldite on all my tanks (Tiger, Comet, PanzerIII) and over the last 5 years they have done a lot of running through mud water and all sorts and none of them have come off. But it's all about the preparation of the surfaces, you have to make sure that the tyre rubber is roughed up and clean and also the surface of the wheel.
Dennis.
Dennis.
Also used 24 hour Araldite on my tiger, and like Dennis, it's all in the preparation. No problems so far and I have clocked up 30 hours plus of running. I have tried another 2 part expoxy glues as I was having a problem getting Araldite locally, waste of money...
Garry
1/6 PzKfw III
1/6 PzKfw III
- Luc De Weirdt
- Been liked: 16 times
Hi Yves,yves mouton wrote:Hello,
best regards Yves
Once the bottle is opened you can keep it in the refrigerator. That way the Loctite stays good for months.
![Wink :wink:](./images/smilies/icon_wink.gif)
