NOW OPEN
CLICK HERE FOR MORE DETAILS
Rubber to metal glue
duncanallender
Been liked: 8 times
Post by duncanallender »
Hi Chaps.
Some of my tyres have come loose from the wheels on my Firefly.What might be the best glue to use and can you say where I might buy it from.
Duncan
Walter Mackinnon
Has liked: 8 times
Been liked: 4 times
Re: Rubber to metal glue
Post by Walter Mackinnon »
Hi Duncan,
Did you use the Loctite 410, I used it on myT34/85. From Bearing Shop sales@bearingshopuk.co.uk
Walter.
duncanallender
Been liked: 8 times
Hi Walter
Ta for the reply. I didn't make the tank so wasn't sure what the previous owner used.I'll try your recomendation.
Dunc
leesellars
Been liked: 15 times
Post by leesellars »
Duncan
You want loctite 480
lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
duncanallender
Been liked: 8 times
Cheers Lee
yves mouton
Been liked: 603 times
Post by yves mouton »
Hello,
Yes thats the one nr 480 Loctite,
it's a black substance, once the bottle is open you can use it for
maybe 6 weeks, than the glue becomes hard in the bottle.
I use that for my tiger roadwheels and they donth come of.
best regards Yves
Has liked: 1024 times
Been liked: 2094 times
Loctite 480 is very effective but not cheap. A while back, we discussed an alternative UK source which is much cheaper:
http://www.shop4glue.com/about-1-w.asp
I haven't exhausted my supplies of various Loctite products yet but when I do, I'll be giving these folk a trial run.
Hope that helps.
Derek Attree
Has liked: 218 times
Been liked: 183 times
Post by Derek Attree »
Hi Guys
I have used this on my Comet and it seems to be the same as the
Loctite 480.
http://www.shop4glue.com/50g-flexy-cyan ... e-87-p.asp
The delivery was a bit slow but they sent the goods and ask for payment after they arrived.
They normally are at the midland ME shoe in Warwick and that starts on the 16th.
duncanallender
Been liked: 8 times
Thanks chaps,
Might give the FlexyCyano a go. Let you know how I get on.
Dunc
paul&robinmargle
Been liked: 2 times
Post by paul&robinmargle »
I just used Araldite 2 part epoxy. Make sure it's the 24 hour one and not 5 mins.
Robin
Dennis Jones
Has liked: 10 times
Been liked: 223 times
Post by Dennis Jones »
I like Robin have used good quality 24 hr Araldite on all my tanks (Tiger, Comet, PanzerIII) and over the last 5 years they have done a lot of running through mud water and all sorts and none of them have come off. But it's all about the preparation of the surfaces, you have to make sure that the tyre rubber is roughed up and clean and also the surface of the wheel.
Garry Coomber
Post by Garry Coomber »
Also used 24 hour Araldite on my tiger, and like Dennis, it's all in the preparation. No problems so far and I have clocked up 30 hours plus of running. I have tried another 2 part expoxy glues as I was having a problem getting Araldite locally, waste of money...
Garry
1/6 PzKfw III
Luc De Weirdt
Been liked: 16 times
Post by Luc De Weirdt »
yves mouton wrote:Hello,
best regards Yves
Hi Yves,
Once the bottle is opened you can keep it in the refrigerator. That way the Loctite stays good for months. :wink:
