Hi tankers
My JagdPanther is going to have a major makeover which includes:
Wheels of - new bearings etc
Suspension to be adjusten to more correct height ( ground clearence is only 5 cm needs to be between 7-9 cm)
New rubber for roadwheels
Cleaning and painting the interior
Mounting a new base plate for batteries
New AGM batteries installation (going from 2 x 24A ACID to 4 x 20A AGM reducing weight by 10 kg
New paint schema
My questions is - are there any particular areas that I need to be aware of practially stripping the tank down and rebuilding it
cheers
Steen
JagdPanther - Advice
- Steen Vøler
- Has liked: 62 times
- Been liked: 500 times
- Been liked: 1 time
Re: JagdPanther - Advice
surprised that you are fitting new bearings and rubbers, mine was one of the first produced, and has been hacked from hell to high water.....still going strong, famous last words all the best denny. and good luck!!!
- Steen Vøler
hi Dennis
thanks for the advice.some of the roadwheels are loose which I suspect to be the bearings.
attached is a picture of one roadwheel where you can see that the bearing is rusty.
also a picture of my home made wheel cap unscrewer
cheers
Steen
Steen
p.s armourtek, havent got any uprated suspensions, at the moment, but i belive going to make some soon, so get your name down..
- Has liked: 264 times
- Been liked: 196 times
Denny
The Wilton-Axminsters, a Yeomanry Regiment, not much use, with a pretensions to grandeur?
What are you doing???? The rust looks beautiful. I thought I was looking at a real tank at first. (LOL)
1/6 Armortek: Panther,KingTiger. 1/6 FOA: Tiger-1,251 Halftrk. 1/6 ArmorHobbies: 250 Halftrk("GRIEF"). 1/6 DML: Kubelwagon,Kettenkrad. 1/16 Trumpeter KingTiger. 1/24 Tamiya: Tiger-1,Panther.(& a countless host of others too small to mention)
