Smoke system question
John Grima
Been liked: 48 times
Post by John Grima »
Hello Everyone. While working on the smoke system I had a question on what type of fluid to use. On my builds I use this fluid which is designed for model boats and trains,
The Fluid is paraffin based, and I was curious if this fluid will be compatible with the armortek smoke system.
Thanks in advance
Paul Morris
Been liked: 68 times
Re: Smoke system question
Post by Paul Morris »
Hello John.
I always use Parrafin in my tanks will Armortek smokers never had any trouble at all so SHOULD be fine.
Cheers Paul. :wink:
01524 720977
yves mouton
Been liked: 621 times
Post by yves mouton »
Hello John,
I use baby oil ( Galenco ),
its a white plastic bottle with a green cap.
I buy this in a pharmacy,and it smokes very good.
best regards Yves
Luc De Weirdt
Been liked: 16 times
Post by Luc De Weirdt »
I use baby oil. Works fine! 8)
John Grima
Thanks guys, Also I'm also checking to see if the matting is mounted right. I read the instructions but was just checking to see if I had the mat in the right spot before I progress.
Once I know I can continue with the builds 8)
Has liked: 1424 times
Been liked: 1604 times
The matting should be in a kind of Omega shape:
_( )_
With the two flat parts in the bottom of the smoke box and the element up the O part of it. This means the element is completely surrounded at all times, so you shouldn't get any hot spots, which could shorten the elements life.
John Grima
Thanks Adrian, makes a lot of sense.
