Armorpax's 25 Pounder
Dave Dibb (Armorpax)
Has liked: 116 times
Been liked: 1106 times
Re: Armorpax's 25 Pounder
Hi MArucs,
Its releived slightly on that side and does clear the nut. I've just remade the Handspike and brackets as when I fitted the castings this morning they looked a little undersized :roll:
Some pics of the fitted box and a few other bits later on :D
Dave
www.armorpax.net
Marcus Kwa
Been liked: 39 times
Post by Marcus Kwa »
Am I glad I still have not removed my Christmas tree as a new present just arrived!!!
Gorgeous, just gorgeous! These are bound to be popular! Thanks Dave!!
Marcus
Marcus Kwa
Excellent work Dave, parts fit perfectly (also testament to the dimensional control of Armortek!!)! Rivet holes are spot on! Clean-up is very straightforward and all parts were installed in half an hour.
Have to redo the rivets though, since I decided not to use the kit rivets. Those smaller rivets do look smart but they are a pain to install in the existing holes, sometimes...... :roll: .
Everyone using the kit rivets will have nothing to fear!!!! :lol:
Marcus
Hi Marcus,
You are more than welcome. There is no way I would use your brake drum without you taking something in return :D
There will be a second parcel once the other parts are done. I will keep a note on your build and fill in the gaps. :wink:
Very best regards
Dave
www.armorpax.net
Hi All,
I added the gunners seat lock to the breech detail mould block. I've also made another of the lower trail angles.
Cast texture has now been added to the barrel counterweight and as I am remoulding the Handspikes made the other breech detail part to go in a mould tonight.
Dave
www.armorpax.net
Leon Benjamins
Post by Leon Benjamins »
Dave, I see you are using a hex bolt on the breech, but a square bolt was used on the original.
I'm using a Armortek Tiger rear deck bolt that I sand down a bit.
Hi All,
New breech detail parts and welds added. New Handspikes done and fitted and one shown in the rear socket.
Bolt changed to a square head also, well spotted Leon :D
I am doing the bottom angle that is still missing, the two storage boxes and the foot pedal assembly for the handspike sockets then thats the update kit done. It wil include 40 tie downs, which I think is how many needed but wil confirm once I have fitted them.
Anything else will be small one off additions.
Dave
www.armorpax.net
Hi All,
First of the new storage boxes done. It will be going in a mould later this week.
Dave
www.armorpax.net
Hi All,
Tray done and first spare parts box fully finished.
Dave
www.armorpax.net
Hi All,
Larger of the two boxes finished.
Dave
www.armorpax.net
Hi All,
Handspike socket foot pedal done.
Dave
www.armorpax.net
Hi All,
Last of the rear trail angles done. Mould plate seemed a little empty so made the travel lock parts too. As its a flat back casting it will only work in the stowed position against the left trail arm but its a bonus piece.
The little handle is for the sight opening cover.
There is one more small plate detail that goes on the back of the Breech block that I'm going to add to the mould then thats it for the kit parts.
Dave
www.armorpax.net
Marcus Kwa
I had just started that transport bracket........ :wink:
Also working on a gunsight by any chance? :D
Marcus
Hi All,
That's all the new parts done and fitted. I need a few days to make sufficient production moulds where there are multiples but should be ready to start producing kits by the end of the week. I will post details in a few days.
Dave
www.armorpax.net
Marcus Kwa
Excellent Dave!
Even the locking plunger on the foot pedal is included!
How did the gunshield fit on your gun? For some reason the guntube cutout is not centered on the guntube itself.
Marcus
