thank you
There is a wide range of work( just the normal rework I think) on the KIT content, plus my individual changes and add on's. That is what makes the fun on the build, isn't it ?
Today I've finished vs. added again some bits and pieces on the recoil tube and breechblock and I'm happy for now with the result ..
The quite little insert on the "Spanner" blocker has been flown away three time, so I'm fed up for now and it is time to go for some bigger parts of the Flak
Uwe
"Nut Lock" feature added
bracket on the recoil tube added
details added to the breechblock
1:16 Models: Kingtiger
1:10 Models: Flak-Panther Coelian, Panther A , S.WS with 3,7cm Flak 37
1:6 Armortek Models: Flak 36 2006, Kingtiger 2013, PAK 43/41 2015, SdKfz 251 2016, FAMO 2018
1:6 other Models: Opel Blitz , Kübelwagen , Zündapp KS750 etc...
Made a bit of progress and finished so far the cruziform.
For now the cruziform is just as it is out of the KIT to get the fit & functions along..
With some "obstacles" I managed finally to get the gun on the base and the leveling working smoothly
A million treads made ok, I found the only one helicoil insert
Maybe I should play Lotterie
cheers so far,
Uwe
and the winner is ;-)
slowly looking like a Flak :-)
I'm getting really curious to see your fantastic Flak in real !
So many great details on it, wow
Don't worry about your "electric connector", its original just the power air connector for the boogie power brakes Just kidding
The connector looks great allready
cheers ,
Uwe
still busy with the cleaning up and preparations on all the cast parts for the next steps. Not much time left at the moment for the FLAK
I've had a look at the "Trilex" wheel components and had to do "some" corrections
Today I've finshed at least the first step, centering and shape corrections on the inner stars.
Next step to get the surface mods blasted to align the appearance
cheers so far,
Uwe
Axis centred and shape partly reworked
Before and after the next step
In between business and family demands I made at least some progress on the Trilex Wheels.
The blasting op has to wait a bit, so I made some other mods on the "wheels-story".
Up 'till now I'm quite happy with the results and can finalize it once the missing bits and pieces are in place Anybody an idea what will be realized
Attached are some pics of the progress so far,
cheers,
Uwe
One of the two axles ready running smooth and round
modified a bit the hub caps, the rims and added the valves
modified the brake backplate and added allready some details for the brakes
shaped a bit the brake drums and made the bolts
I couldn't find ready ones so I made the thicker washers and nuts myself.
Busy with the bolts for the movable cruciform legs and some shaping on the small bits and pieces for the cruciform..
Hi Paul
it took a bit more than just spinning around, but it's not that complicate
cheers ,
Uwe
made new fixings for the base
