Uwe's 88
Forum for discussion relating to the 88mm Flak36
Paul Wills
Has liked: 646 times
Been liked: 143 times
Re: Uwe's 88
Post by Paul Wills »
Uwe, ist diese erstklassige, fantastisch. 8) :wink:
Paul. :wink:
Uwe Gerstenmayer
Been liked: 72 times
Re: Uwe's 88
Post by Uwe Gerstenmayer »
Hello Stephen,
thank you :!: :oops:
There is a wide range of work( just the normal rework I think) on the KIT content, plus my individual changes and add on's. That is what makes the fun on the build, isn't it ?
Today I've finished vs. added again some bits and pieces on the recoil tube and breechblock and I'm happy for now with the result ..
The quite little insert on the "Spanner" blocker has been flown away three time, so I'm fed up for now and it is time to go for some bigger parts of the Flak :roll: :lol:
Uwe
"Nut Lock" feature added
bracket on the recoil tube added
details added to the breechblock
1:16 Models: Kingtiger
Leon Benjamins
Re: Uwe's 88
Post by Leon Benjamins »
Beautiful work so far! Wish I had the craftmanship to do this work.
Iacopo Di Giampietro
Been liked: 48 times
Re: Uwe's 88
You're doing a really amazing job, congratulations!
Uwe Gerstenmayer
Re: Uwe's 88
Hello and thanks to all interested in my build :) :D
Made a bit of progress and finished so far the cruziform.
For now the cruziform is just as it is out of the KIT to get the fit & functions along..
With some "obstacles" I managed finally to get the gun on the base and the leveling working smoothly :wink:
A million treads made ok, I found the only one helicoil insert :shock: :lol:
Maybe I should play Lotterie :lol:
cheers so far,
Uwe
and the winner is ;-)
slowly looking like a Flak :-)
Has liked: 1490 times
Been liked: 1695 times
Re: Uwe's 88
I'm loving all the little details on this 88 Uwe :D
Paul Wills
Re: Uwe's 88
Hi Uwe,
Looking better and better my friend. I think you will have yours finished before me :shock: :D
Paul. :wink:
Uwe Gerstenmayer
Re: Uwe's 88
Hi Paul,
I'm getting really curious to see your fantastic Flak in real ! 8)
So many great details on it, wow :!:
Don't worry about your "electric connector", its original just the power air connector for the boogie power brakes :roll: :lol: Just kidding
The connector looks great allready 8)
cheers ,
Uwe :wink:
Uwe Gerstenmayer
Re: Uwe's 88
still busy with the cleaning up and preparations on all the cast parts for the next steps. Not much time left at the moment for the FLAK :(
I've had a look at the "Trilex" wheel components and had to do "some" corrections :shock: :wink:
Today I've finshed at least the first step, centering and shape corrections on the inner stars.
Next step to get the surface mods blasted to align the appearance :)
cheers so far,
Uwe
Axis centred and shape partly reworked
Before and after the next step
Tim Bowman
Been liked: 177 times
Re: Uwe's 88
Post by Tim Bowman »
Hello Uwe
Amazing! :shock: :shock: :shock:
Enjoying your 88 project very much. Incredible detailing Uwe.
Best regards from California
Uwe Gerstenmayer
Re: Uwe's 88
Hello Tim,
thanks a lot :D :!:
In between business and family demands I made at least some progress on the Trilex Wheels.
The blasting op has to wait a bit, so I made some other mods on the "wheels-story".
Up 'till now I'm quite happy with the results and can finalize it once the missing bits and pieces are in place :wink: Anybody an idea what will be realized :roll: :wink:
Attached are some pics of the progress so far,
cheers,
Uwe :wink:
One of the two axles ready running smooth and round
modified a bit the hub caps, the rims and added the valves
modified the brake backplate and added allready some details for the brakes
shaped a bit the brake drums and made the bolts
Paul Wills
Re: Uwe's 88
Hi Uwe,
Very nice 8) 8) and no I have no idea :!: :oops:
Paul. :wink:
Uwe Gerstenmayer
Re: Uwe's 88
Just have made a new leveling bolt to sort out my "Helicoil" win :shock: :wink: :lol:
Working again on the cruciform I started with the first mods....
Hi Paul,
it works quite nice :idea: :wink:
cheers,
Uwe
Paul Wills
Re: Uwe's 88
Hi Uwe,
Looking really nice now 8) Did you have to move the main spindle hole :?: or have you been lucky and the housing just spins round :) :wink:
Not had time to do anything on mine this week, too much to do at work :cry:
Paul.
Uwe Gerstenmayer
Re: Uwe's 88
Some small progress on the base.
I couldn't find ready ones so I made the thicker washers and nuts myself.
Busy with the bolts for the movable cruciform legs and some shaping on the small bits and pieces for the cruciform..
Hi Paul :)
it took a bit more than just spinning around, but it's not that complicate :wink:
cheers ,
Uwe
made new fixings for the base
