Sherman re-build
- Has liked: 4 times
- Been liked: 245 times
Sherman re-build
Hi I recently purchased a second hand original Sherman kit that had been partially built and never finished. I have stripped it down and have started refurbishing it for a gradual rebuild over the next few months. I am converting the body so that it is removable in exactly the same way as the Tamiya Sherman to make access to the internals very easy.
- Has liked: 10 times
- Been liked: 224 times
Re: Sherman re-build - update
Thanks,
- Has liked: 140 times
- Been liked: 803 times
Mark your Sherm is looking good. The gear cases don't really need any grease, but a little on the teeth of the big gear won't hurt. I wouldn't pack it full, the grease and oil will separate and the oil will leak out of all seams. It looks realistic but is a dust and dirt magnet. I learned the hard way.
Re: Sherman re-build - problem
Thanks,
- Has liked: 198 times
- Been liked: 748 times
- Has liked: 1453 times
- Been liked: 1623 times
As David says, but I also filed the return roller axle down so that it was level with the top of the pillow block.
- Been liked: 48 times
Re: Sherman re-build - more progress
Hi more progress on the Sherman re-build. I countersunk the return roller axle fixing screws and this resolved the track horn clearnace problem. Some more pictures on the build follow. The electrics are going in, some temporary as I am waiting for a Benedini sound unit. The body and turret have been etch primed ready for finishing details to be applied. I need to get some speakers - any advice as to the best type and size and how to mount them?
Thanks,
Thanks,
- Been liked: 177 times
Hi Mark
Looking good! Nice to see another Sherman.
Good progress Mark
I've been very impressed with the Tannoy ones Armortek are supplying.
One should fit either side of the smoke module, at the back.
Hi Adrian do you know what the part number is for the Tannoy speakers that Armortek use?
Thanks,
Thanks,
I think they are Tannoy SFX 5.1 satellite speakers.
They make black and silver versions.
Hi just finished building and etch priming the turret and body. Most of the electrics now installed in the chassis.
Some more progress on the re-build. Hatch handles and welds added plus other minor details.
Thanks,
Thanks,
