The model maker added the zimmerit, and lots of after market parts from 6th Scale Icons, and completed most of the exterior detailing.
The builder never completed the RC work, and from what I can tell the model has never been tested or driven.
The turret's machinery was also never completed, and it is missing the gun barrel and muzzle brake.
Before I was able to start on the model I had to inspect the suspension and running gear to check to see if it was assembled properly. It was lucky that I did so because in the condition that the model was is in... it would have broken down, or would have had serious damage happen to the drive train and the running gear.
The shoddy workmanship would include, loose wheel retaining bolts, improperly mounted sprockets / final drive mounts, improperly mounted torsion bars, loose bolts...etc.
To correct these issues I needed to unassemble the model. Starting with the sprockets.
After the sprockets were removed you you can see that the builder failed to properly lubricate the final drives.
On the swing arms the builder failed to lock the axles. Because of this the axles would have the chance to unscrew themselves while the tank would be diving, and would cause such problems as misaligned wheels to suspension sag.
To fix the problems I drilled wholes through the swing arms and inserted a small pin. After the pin is expanded the axles will never be able to unscrew. After the pinning the swing arms were remounted.
The builder also failed to paint the lower hull, and failed to properly prime and paint the swing arms.
Another area that was missed by the builder was the gaps on the sponson. These gaps are present because of the way the panels are laser cut and folded.
These gaps were filled, and blended. Also weld beads were sculpted into the seams as well as the areas that were missed by the builder.
On the front final drive mounts I added the missing final drive mount bolt, tension straps, welds. and I replaced the armored collar hex bolt with a counter sunk bolt. This bolt was then blended into the tank via body work (not shown)
After the revisions were completed I remounted the wheels. Prior to mounting the wheels I added their weathering, since these areas will be very difficult to paint when assembled and mounted. Like the real tank the wheels are mounted in layers
One unique feature about the kit is that the wheels have O ring that give a secure sealing between the wheels. To aid in the mounting I used four small drops of CA to tack the O ring to the wheel, so that when mounting the O rings won't fall out.
After the wheels were mounted. I used thread lock to help prevent the bolts from getting loose.
Two Youtube videos were created,
One showing the model when I first got in the shop,
The other showing the mistakes, and the work required to correct the issues:
Images were also posted on facebook: https://www.facebook.com/EastCoastArmory
I'm also looking for a replacement gun barrel and muzzle brake. If anyone has one, or knows where I can acquire one PM me.
For this build I will now be focusing on getting the model to run, and the functions. More to come
