Lighting wiring question
- Been liked: 48 times
Hello all, I'm currently working on one of the older Armortek Panther kits. On the tank I have what I believe is the Steve Winston headlight and taillight tube. Does any one know what voltage these bulbs are? I'm currently hooking them up and I don't want to burn them out.
- Been liked: 15 times
Re: Lighting wiring question
Hello John
They are both 12vdc.
Lee
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
- Has liked: 10 times
- Been liked: 224 times
Hi John,
I just connect the 2 in series and then you can drive them from the 24 volt aux socket or the blank fire output on the aux module. If you use the aux output you will need a diode in series.
Dennis.
Dennis.
Thanks guys,
Dennis, That's exactly what I had in mind, but was not sure if the bulbs were going to be able to take it.
I'm now off to soldering will post some progress pics in my panther post soon.
- Has liked: 26 times
- Been liked: 103 times
g'day guys,
on behalf of the light wiring dummies can i ask if someone could post a wiring diagram for the headlight and one with rear light showing what wire connects to what position/connection/terminal.
thanks on behalf of dummies.
ray
ray
Ray, Currently I got a youtube video uploading that shows how I hooked up my lights to a switch and the armortek power system. once uploaded I'll post the link in my panther build blog post http://www.armortek.co.uk/Forum3b/viewt ... =10&t=4496
excellent. thanks john look forward to it. i have a set of your tiger cooling fans i want to connect up soon as well.
cheers
ray
cheers
ray
Hi Ray, I added the video link and images to my Panther build blog, http://www.armortek.co.uk/Forum3b/viewt ... 308#p39308
Hooking up the fans is very similar. If you need me to draw up a drawing of the layout let me know.
got it john. however i'm wanting to turn headlight on using rc switch and fans when vehicle starts as per smoke.
if anyone can help with that it would be greatly appreciated.
cheers
ray
cheers
ray
