Track joining rig
Track joining rig
Simple does the job. I hardly had to swear at all!
- Been liked: 14 times
Re: Track joining rig
Bob,
Nice one mate. I have gone with the cheap n cheeful option on the Sherman before. If the vehicle is on a table then using a racheting strap to press down and compress the suspension will generally make enough slack to to slip the track pins though.
Going to make a turnbuckle tool like yours to take down to the woods for driving days. Thanks for sharing.
cheers Fabrice
cheers Fabrice
Fabrice. Cheap n cheerful but It does the job
Problem with a KT is the tracks are very heavy and the pins have to go through several bearings so i need the precision tighten/slacken feature of a mini turnbuckle. The turnbuckle i use is a M4 from ebay at about £2.99. Its only a couple of inches long closed
- Been liked: 741 times
Hello Bob,
I also use 2 racheting strips on my tanks,
and this works very good.
For me the best way to do this, you let the tank a little bit touch the ground with
the tracks. Than i put the tracks together ath the front, just under the trackwheels.
best regards Yves
best regards Yves
I'm sure cable ties work well...but its just far too easy for me. I live a complex life
- Has liked: 1566 times
- Been liked: 836 times
Me to, Bob, I loaded around seventeen paving blocks in the hull.....that did the trick
....Mick
- Chang
- Has liked: 16539 times
- Been liked: 487 times
Hi Bob,
That is a nice tool and idea to do the job.
I used two to three G-clamps to do the work, under the idle wheel area. For Olaf's late type track a bit harder because of the double weigh.
Lerh Chang
Lerh Chang
