Track joining rig
Bob Gould
Been liked: 31 times
Track joining rig
Post by Bob Gould »
Simple does the job. I hardly had to swear at all! :)
Fabrice Le Roux
Been liked: 14 times
Re: Track joining rig
Post by Fabrice Le Roux »
Bob,
Nice one mate. I have gone with the cheap n cheeful option on the Sherman before.
cable tie track strap
If the vehicle is on a table then using a racheting strap to press down and compress the suspension will generally make enough slack to to slip the track pins though.
Going to make a turnbuckle tool like yours to take down to the woods for driving days. Thanks for sharing.
cheers Fabrice
Bob Gould
Post by Bob Gould »
Fabrice. Cheap n cheerful but It does the job :D Problem with a KT is the tracks are very heavy and the pins have to go through several bearings so i need the precision tighten/slacken feature of a mini turnbuckle. The turnbuckle i use is a M4 from ebay at about £2.99. Its only a couple of inches long closed
yves mouton
Been liked: 603 times
Post by yves mouton »
Hello Bob,
I also use 2 racheting strips on my tanks,
and this works very good.
For me the best way to do this, you let the tank a little bit touch the ground with
the tracks. Than i put the tracks together ath the front, just under the trackwheels.
best regards Yves
Bob Gould
Post by Bob Gould »
I'm sure cable ties work well...but its just far too easy for me. I live a complex life :shock: :lol: :lol:
michael hilton
Has liked: 1564 times
Been liked: 835 times
Post by michael hilton »
Me to, Bob, I loaded around seventeen paving blocks in the hull.....that did the trick :shock: ....Mick
Chang
Has liked: 16075 times
Been liked: 454 times
Post by Chang »
Hi Bob,
That is a nice tool and idea to do the job.
I used two to three G-clamps to do the work, under the idle wheel area. For Olaf's late type track a bit harder because of the double weigh. :lol:
Lerh Chang :)
