Bob Goulds Noob Late Tiger :-)
John Fitzsimons
Has liked: 6 times
Been liked: 822 times
Re: No 012 - Bedroom Build
Post by John Fitzsimons »
Ouch. When I saw your thumb without my glasses I thought it was a really crappy animatronic figure.
The turret wrap is difficult to close. Tighten the bolts only gradually and careful not to strip. I had to file a lot off the section into which the gun sits to make it move freely.
Bob Gould
Been liked: 31 times
Post by Bob Gould »
:lol: Duel purpose insulating tape; great for stemming blood flow, oh and ok for insulating stuff as well!
I had the turret complete, and like you had to do copious amount of filling.
But the gun didn’t elevate smoothly, it was grinding and was at a slight angle.
Others prolly wouldn’t notice but it annoyed me. So i stripped it down and noticed that one side had a slight twist in the wall at the front. The top lug that traps the gun elevation frame in place was not aligned to the bottom lug.
Now i have twisted it back with the tensioner the gun elevates perfectly. Just got to run a M4 bolt through to hold it in place.
Bob Gould
Post by Bob Gould »
Update
My first Zim test
My first Zim test
Turret frame pinned in the correct position
phil fitzpatrick
Been liked: 223 times
Post by phil fitzpatrick »
Hi Bob
Is that the extra Pin in the front that you used to line things up,
in your second picture?
That looks like a roll of black insulation tape on top of your deck
in the 1st picture,keeping the first aid equipment close at hand now :)
Paul Morris
Been liked: 68 times
Post by Paul Morris »
Hi Bob.
Could be an idea to scuff up the metal where you are doing your zimm just to give it something to hold onto.
Cheers Paul :wink:
01524 720977
John Fitzsimons
Has liked: 6 times
Do'nt worry Paul. Already sent pm and mentioned your technique involving scuffing the metal.
William Gardeniers
Has liked: 46 times
Been liked: 282 times
Post by William Gardeniers »
Hi John why don't you let us al know how to scuffing the metal.
Thanks William
With Regards William
Paul Morris
Hello William.
Its no great secret I have put it on the forum somewhere I always use an old modelling knife and simply cross hatch the suface to be zimmed or a coarse grade oxide paper will do the same job, just to give the milliput a key to get hold of.
Hope this helps mate if not just give mea shout always happy to help.
Cheers Paul. :wink:
01524 720977
John Fitzsimons
Has liked: 6 times
I imagine this would help with all zimmerit applications and not just milliput.
William Gardeniers
Has liked: 46 times
Thanks John and Paul
Cheers William
Paul Morris
Ha ha don't worry about it, its no problem :roll:
01524 720977
Bob Gould
Post by Bob Gould »
Phil. Yes that's one of the pin after filling with insta metal. I pinned 3 of the four lugs. The turret roof sits much neater now and the elevation is smooth. But more importantly the gun sits straight.
As for the tape, i need it a lot these day, cut my hand the other day. 3 stiches!!
Paul, John. Many thanks for the help and advice for Zimmerite'ing. Have ordered miliput x 10 then im going for it.
Bob Gould
Post by Bob Gould »
Applying Zimmerite (milliput) SUCKS!! :x
and there's so much of it to do!
John Fitzsimons
Has liked: 6 times
Patience Bob. Takes lots. I like zimmerit. Prefer the yellow and grey though. Bit more coarse and better base color for painting. Probably cheaper also. Think happy thoughts.
Andrew P Walker
Post by Andrew P Walker »
Hi Bob,
Great blog - really helpful to a newbie like me - I have just recently embarked on my Late Tiger 1 (my first step up from 1/16th) and I have a similar issue re the turret wrap twisting away at the top of the turret front. I'm thinking I may have to try what you have done and "pin" through the top lug. Did you just drill and tap a standard thread? And did you go right through the turret front into the main part of the turret wrap?
Andrew
