Panzer IV Build 002
Ray Brown
Has liked: 26 times
Been liked: 103 times
Re: Panzer IV Build 002
Post by Ray Brown »
g'day.
nick - i loosened the nuts & bolts you suggested & filed the corners of the front plate but still ended up with the gap. i`think this is because the bracket holes are to high. i'll just fill it with bog for now.
all - something else i've noticed. armortek manual shows rear deck grills as below, yet muesum tank photos show grills are flat. what is the general concensus, flat or lower?
Günter Gäbelein
Has liked: 41 times
Been liked: 195 times
Post by Günter Gäbelein »
Hi Ray,
I decided to modify the deck grills. I had photos of the original tank.
The result of my modification is that
Günter
Nick Farrugia
Post by Nick Farrugia »
HI Ray
i have stuck with the armortek version on mine ,at the end of the day its up to you what you prefer .sorry you had no luck with the gap at the front ,if you check out Gunters build he has got a piece of metal going across the bottom edge (a shot deflector i think )this should help cover the gap up ,i only had a small gap on mine when i added the strip it realy looks neat . your build is coming on well keep the pics coming .regards ,,,,,,,,,,,,,,,,,,,,,,nick
Ray Brown
Has liked: 26 times
Post by Ray Brown »
first go at brazing brass. thanks to the tutorial i'm happy with the result of my jerry can bracket. cheers.
074 03-02-12.JPG (153.58 KiB) Viewed 10307 times
075 03-02-12.JPG (124.08 KiB) Viewed 10307 times
076 03-02-12.JPG (118.73 KiB) Viewed 10307 times
Günter Gäbelein
Has liked: 41 times
Hi Ray,
the bracket looks fine!
Günter
Nick Farrugia
HI Ray
great job on on the jerry can holder :D very profesional well done ,whats next?
regards,,,,,,,,,,,,,,,,,,nick
John Fitzsimons
Has liked: 6 times
Been liked: 822 times
Post by John Fitzsimons »
Very neat. Well done.
Ray Brown
Has liked: 26 times
Post by Ray Brown »
thanks guys.
next job nick is to replicate your nan's coal bin.... :lol:
Ray Brown
Has liked: 26 times
Post by Ray Brown »
went to put the turret bin on. someone measured wrong.
Nick Farrugia
HI Ray
mine was the same i think it does say in the book it needs fine tuning ,so what i did was get the side brackets fitted and then hit it with a big soft faced mallet :lol: to get it into position ,a bit unsivilised i know but it did the trick , good luck
all the best ,,,,,,,,,,,,,,,,,,nick
Ray Brown
Has liked: 26 times
Post by Ray Brown »
update on vehicle
078 28-02-12.JPG (192.23 KiB) Viewed 10163 times
with Nick's fuel caps.
081 28-02-12.JPG (227.66 KiB) Viewed 10163 times
079 28-02-12.JPG (125.97 KiB) Viewed 10163 times
Ray Brown
Has liked: 26 times
Post by Ray Brown »
082 28-02-12.JPG (121.38 KiB) Viewed 10163 times
Nick Farrugia
HI RAY
She is looking good you are making steady progress the jerry can,s and rack look great and its nice to see the fuel caps in place :D ,i see you still got a lot of bolts to do :( i found it daunting to do it seems to never end ,what i did was just do one or two wheels a night it didnt feel to bad then :) .i will be putting the tracks together over the next few days carnt wait to see them on ,your,s looks so good with them on :) looking forward to your next posts .
best wishes to you ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,nick
Has liked: 163 times
Been liked: 849 times
Ray,
Fantastic looking P4, I love how the details stand out in the grey primer. Keep up the great work. Best regards,Bob
Ray Brown
Has liked: 26 times
Post by Ray Brown »
finally did one side of the tank running gear.
