Adding Photos to the Gallery
Steve Norris
Has liked: 8 times
Been liked: 697 times
Post by Steve Norris »
Thanks Ad, I will give that a try.
Mike Gormley
Has liked: 5 times
Been liked: 6 times
Post by Mike Gormley »
Ad,
It shows me as guest too
I have posted for Mark in the "Gallery now working " thread.
It could be this is why I can't upload pictures to my album.
Mike
Ad Wouterse
Been liked: 2 times
Post by Ad Wouterse »
Mike,
Yep, that is exactly what I had on my page before Mark Mitchell solved it.
It concerns an error in the registration procedure.
Don't worry, Mark will fix it :wink:
Ad
Steve Norris
Has liked: 8 times
Well i can now get the "add Photo" page, but when i select a photo and hit "add item" nothing happens for a while and then i get a white screen.
Am i doing something wrong ?
Steve.
Patrick O'Donnell
Post by Patrick O'Donnell »
Steve,
It could be that the file size and/or pixel count is to big.
Patrick
Rene, "Would you like a ride in my little tank?"
John Sander
Post by John Sander »
I run a few photo galleries, and from experience can recommend the "Windows XP" option. This appears as one of the tabs when you select Add Picture. Click on the tab and you get simple instructions on how to use this option. The result is, when you are viewing pictures on your (Windows XP) PC, you can use the "Publish this folder (or picture, it's context dependant) to the Web" command.
This provides for a very simple and reliable method for creating or updating your photo albums.
Kampgruppe vonAbt :: Dedicated to the Art
Mike Gormley
Has liked: 5 times
Been liked: 6 times
John,
I might just give that a shot.
Thanks for the info
Mike
Steve Norris
Has liked: 8 times
Many thanks John,
Tried your tip and everything now seems to work.
Graham Ord
Has liked: 4 times
Been liked: 15 times
Uploading photos
Post by Graham Ord »
I have tried to upload photos into my folder in the gallery. I put in the path to the photo via browse, add a title and the press create. The system appears to do it but then hangs up on a blank screen saying "done" at the bottom. I have tried reducing the picture size but still no success. Any solutions please?
Graham
John Sander
Hi Graham. I just tried the same method you are using, and I had exactly the same result as you - a blank screen with the "Done" comment in the status bar. I have researched the cause, and the problem is caused by the EXIF add-on not functioning correctly. Mark - I suggest you either disable the EXIF add-on, or try and resolve the configuration problem with it.
Mike Gormley
Has liked: 5 times
Been liked: 6 times
John,
I tried the Windows XP method and it works great
Thank again
Mike
Graham Ord
Has liked: 4 times
I am trying to follow the instructions for Windows XP Add Items in the Gallery. I am a novice with computers - where is the configuration file? to download. What does it mean " download [install_registry.reg] Can someone put the instructions in novice terms.
Graham
Mike Gormley
Has liked: 5 times
Been liked: 6 times
Graham,
The file name inside the parentheses is the configuration file just click on it and a window will pop up and ask if you want to save it or run it and you want to save it so click on save and it will save it to your desktop on your computer. Then right click on the file and a menu will appear. At the top of the menu you will see the word merge click on it and a window will pop up then click on yes and it will add some settings to the windows registry.
Once this is done you can then go to the folder where your pictures are and
on the left side of the screen under "file and folder tasks" you will see a selection that says "publish this folder to the web" when you click on a picture it will change to "publish this file to the web" . Click on this selection and a window will pop up click on next and then you will see a widow that gives you two web pages to choose from one of which is th link to the Armortek Gallery click on this one to select it and then click on next and you will get the logon window for the Gallery. put in you id and password and hit enter and your picture will be uploaded to your album.
just go to the folder where you keep your pictures and select the picture you want to upload anytime you want to add one to your album and click on "publish this file to the web"
you can upload more than one picture at a time also.
hope this helps
Mike
Graham Ord
Has liked: 4 times
Thanks Mike
It all seemed to go well, how long does it take for the pictures to appear on the site. I uploaded them on 25/7/2007 at approx 8.00 gmt. I had assumed they would appear striaght away?
Graham
Mike Gormley
Has liked: 5 times
Been liked: 6 times
Graham,
They should have shown up right away.
You may have to contact Mark Mitchell as there may be a problem with your Gallery registration.
Mike
