PANZER IV BUILD no 012
Nick Farrugia
Re: PANZER IV BUILD no 012
Post by Nick Farrugia »
Hi to all
heres the pics of the elevation and depression levels that i was on about earlier the elevation doesnt seem to bad but i will tweak it a bit Image the depresion i think needs a bit more than this ,i know it was less than the elevation but think it should be more than this Image so this will be the next thing to do .Today i,ve been going back to the road wheels on the other side and finished them off (same as beforeso no pics) i then went back to the exhausts and cut them down to the correct size now i have the deck in place Image
Image i then fitted the inner pipes .(in my junk box in work i found a piece of rubber that was of a break cable or clutch cable it was star shaped in section and i thought it might look good down the inside of the outer shield and also help keep the center exhaust in position Image
Image what do you think guys ,any way i made the cap that goes over the barrel and attaches to the recoil housing to finish that ofas well Image
Image and heres a pic of that dastidly muzlebreak its never gonna come of again :D Image
Image these next pics are of the weld i did on the turret (the turret is in one piece so these are real fake welds :) )i have been trying new settings and the metal is all one thickness so i think these have come out the best so far Image
Image well i think thats it for this weekend so all the best to all .......nick
Nick Farrugia
errr sorry guys some thing went wrong there heres the missing pics Image
Image well that realy :D should be it thanks for watching
John Fitzsimons
Has liked: 6 times
Been liked: 805 times
Post by John Fitzsimons »
Those welds are prefect. brilliant.
Robert Allsop
Post by Robert Allsop »
Hi Nick,
The welding looks stunning - wish I could do that! Could you tell me how you got the mantlet to fit down in position as it is stopped by machining on the gun base on mine? Also how is it attached? I notice the 4 bolts in the front of the gun base look like those pointy things and the bottom edge of the mantlet should be tapered like the top edge - is that correct?
Hope you don't mind me asking.
This really takes boys toys to a new high!
michael hilton
Has liked: 1566 times
Been liked: 836 times
Post by michael hilton »
Hello Nick, can't get over your welding.....you must have A Levels in welding, really does add that final touch.
Outstanding......Mick
Nick Farrugia
Hi john Mick and Bob
thanks for your comments welding and fabrication in aluminium is what i,ve been doing for a long time now so i guess it shows lots of experiance but thanks again glad you like it .Bob i am taking more pics just of the mantlet and turret for you will send it to you when finished ,it is not a broblem i hope it helps
all the best nick
Nick Farrugia
Hi Bob
famous last words i have taken the pics but dont seem to be able to get them all on a pm for you there are a lot so i will try to talk you through it
The mantlet should have eight holes in the back that are threded mine wernt so i had to do them ,m5 tap, next is the brass bearing blocks these fit in the reseses in the back of the mantlet mine didnt needed a bit of filing to get them to fit dont bolt them in place yet ,the mantlet has a groove at the top and is flat at the bottom Image
Image put the studs half way in the brass blocks push the brass blocks and studs into the holes on each end of the recoil housing and breach,the recoilhousing and breach were a snug fit on mine but it still went into the space in the mantlet ,now lower all this through the back of the mantlet ,it will only go in one way it so if it doesnt fit try turning it over Image
Image next is to try putting all this into the turret again it will only fit one way so try it both ways Image Image Image let me know if this helped i have got more pics of how i got more move ment on the gun
all the best nick
ps sorry its long winded but its hard to tell what the problem is so i thought it best to start at the beginning hope this works dont forget if it works then make sure you locktight the ends of the studs in the barrel housing ,good luck
Robert Allsop
That's helped no end thanks Nick.
I notice an extra hole right thro' the block - is that needed for the m/g?
Can't wait for the next steps :P
Nick Farrugia
Hi Bob
glad that it was useful , the hole runs right through the block it doesnt need to be that big a hole ,8mm , you could dril it 4 or 6mm it will be for the wires for the led bulb for the machine gun later on . I have sorted the elevation and depresion of the barrel the first pic is as it was, elevation the second pic is how it is now Image Image these next pics are of depresionof the barrel before and after Image Image As you should be able to see there is a big differance in the before and after pics ,even if i do not use the full move ment that i now have i think its better to ,have it and not need it than need it and not have it. I MUST STRESS THAT THIS IS A PERSONAL MODIFICATION AND NOT SOMETHING YOU NEED TO DO .Next are some pics of my method for doing this ,this pic is of the top of the recoil block ,i just ran a sanding disc on a angle grinder across the top just to take of the apex piece that was fowling on the mantlet Image next is the bottom edge, this needed more taken of than the top did ,how much you take of is up to you , i think i took a bit more than i needed but i can use the limit swiches to stop it where i want when i instal the electricsImage Image well thats it hope this is useful to some ,,,,,,,all the best ,,,,,,nick
Nick Farrugia
hi all
this is the top of the recoil block pic thats missing sorry :D Image ,,,regards nick
Nick Farrugia
Hi to all
I would like to thank every body who has helped me so far in my build ,with extra pics of parts and advise on howe and what is best to do, and even when i,ve , NOT, got it right and the encoragement thanks to all of you .
Their is one persone who has taken time effort and called in some favours to source and print drawings of a panzer 4 H And enlarge them to 1/6 scale and then send them to me, at no cost to me, this i find going above and beyond enything i have experiaced before . I am stuned that you did this for me and with the quality of the drawings ,i am very pleased with them to say the least,i am even thinking of framing one of them when ive finished .
The person is ,,,steve lewington , steve i carnt thank you enough great job . I just thought this needed special mention
all the best and a merry christmas and a happy new year to all
,,,,,,,,,,,,,,,,,,,nick
Nick Farrugia
Hello all
i have done some work on the cupola (camanders hatch) on opening the bag that said cupola hinge i found some sneeky gremlin (not you gill :lol: honest) had put an extra deck hinge in its place ,so muttering that i will run down every gremlin i see when i get it running :lol: i decided to have a go at making one my self. Image i am very pleased with the outcome ,having done that i decided to do the decorations on and around the hatch Image
Image i couldnt see clearly from pic wheather the bolts or rivets in the hatch were countersunk or sticking proud so i counter sunk them anyway hope their right ,i used solid rivets around the inside edge 5/32 dia dome heads and for the rivets in the hatch i used three 5/32 dia solid countersunk rivets ,and then the hinge i used 3/32dia solid dome heads all these rivets are aluminium, around the outside edge i used 1.2mm diameter drill to drill the ten holes around the edge and then cut down nails and glued them in .The nails had a conical shank and top so i countersunk the holes as well Image
Image all together i am quit happy with the result
regards to all,,,,,,,,,,,,,,,,,,,,nick
John Fitzsimons
Has liked: 6 times
Happy Christmas Nick. Love the festive coloured rivets.
Nick Farrugia
Thanks john
a merry christmas and happy newyear to you and your s
regards nick
Steve Lewington
Has liked: 8903 times
Been liked: 323 times
Post by Steve Lewington »
Hi Nick
Thank you for the lovely comments you are more than welcome they are the results of about four months of work at college.
Thank you also to all you guys who sent me the nice thank you messages on the PM system.
I have another two full sets of plans up for grabs if there is any body interested who in building a panzer iv.
The plans are on 10 sheets of A0 translucent paper two sheets have to be joined together to make each side and top views there are side view with shutzen and without showing the mounting hardware for the lower plates.
Please contact me if interested.
Nick ,John, Paul ,Bob and Ray I wish you and all the other builders a very merry Christmas and a wonderful new year
The builds are coming on fantastic guys.
Kindest Regards to you all.
There is no time for peace.
No respite.
No forgiveness.
There is only ......WAR.
