I'm scratching my head until the saw dust leakes out with this one,hope
someone can help.
I cant see how the pivot pins can be screwed there is no clearance to
work with.
The manual says fit the pins after the rest is assembled but this cant be done
from the dry fit I have been trying,not without machineing
I will send the pics to Mark if no one has tried this yet.
T34/85 Mantlet and Turret Front
- Been liked: 223 times
- Been liked: 15 times
Re: T34/85 Mantlet and Turret Front
Phil,
Are you sure you have the right item as a pivot pin??? and that it shouldn't just be a 'pin', ie no bolt head?? I can't say as I don't have any and from the other postings I believe these items were omitted from the bag - don't know if it was everyone. Speaking to Mark he is rectifying this and has the relevant items sorted ready to be sent out.
See also:
See also:
Post subject: Re: Brown's T34 85 #008
Posted: Fri Sep 30, 2011 3:59 pm
Hi Brown
We have made special pivot bolts for the mantlet. These will be sent out to you. Apologies for the omission.
_________________
John.
Plus others!
Plus others!
Hi John
Yes the missing pivot pins came today.
Discovered by Lee when he was studying his manual.
There is no mention of the part number
The bag is marked FA0485 for the T34/85 pins.
It looks to me as though a bit more side clearance in the machined out bit
is needed to screw them in,because the manual shows they go in last somehow.
You need to check with Gill to see if the pin are being sent out automatic or
she is waiting for calls.
I have sent the pic's to Gill to show to Mark.
I found the easiest fix I could so I could continue and it was easy to do
Assembled loose cos I will have to dissasemble to fix to the turret base
and reassemble.
I plopped the pivot blocks in,poked the amended pin up the hole with a screw driver a bit of a
jiggle about and screwed in easy.
No side ways movement
Choped the heads off the Pins and made a slot for a screw driver.
Drilled the side of the Turret front 9.5mm and tapped it so I can get a couple of grub screws
on Monday to plug the holes and leave for access.
They will be covered by the casting finish and can be found if required
Happy Now
and reassemble.
Happy Now
Hello Chaps
I have found this too. You can not fit the pins in for the pivot. How do you do this Mark??
Lee
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Lee I think the Manual and Kit is full of tests and each one you solve Gill sends you
a £100.00 voucher
a £100.00 voucher
Hello Phil
I wish
Lee
I wish
Lee
I bought a '76 and was just wondering if anyone has experienced similar problem with it. I also have a simple question for I guess it's Mark; when these types of problems arise, are the replacement part automatically sent to the purchasers or do we have to request them?
- Been liked: 3059 times
Hello Bill
Some of the issues raised here are not problems at all. They are just individuals having individual issues, thats why we always ask you to contact us directly, and not use the forum as a first point of contact. There is no issue at all with the 76 pivot pins. The 85 is simply addressed, just contact us directly and we will respond.
