The King Tiger's gun mantlet
Chang
Has liked: 16579 times
Been liked: 487 times
Post by Chang »
Hi guys,
Is it only mine or more of our KTs have the little issue that the saukopf mantlet will dropped-down a little bit (as the red arrow indicated) during her moving? If yes, how did you fix it?
Regards,
Lerh Chang
leesellars
Been liked: 15 times
Post by leesellars »
Hello Lerh
Drill and tap a hole underneath the mantlet and the use a grub screw to fix to the barrel. Simples :wink:
lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Paul Morris
Been liked: 68 times
Post by Paul Morris »
Hi Lerh and Lee.
Ditto ...I did exactly the same :)
Cheers Paul :wink:
01524 720977
Chang
Post by Chang »
Thanks leesellars and Paul.
Glad to know it's not only my problem, and a solution is already there. :idea:
I'll fix it, once for all.
Thanks!
Lerh Chang :D
Conrad Sharp
Been liked: 2 times
Post by Conrad Sharp »
Chang, when you have made the fix, can you post a photo so i can see, I'm a bit of a noob when it comes to this hands on stuff, more at home on a keyboard ;-P
On the subject of drilling and tapping, I was just going to buy some, what are the best sizes to get, the smallest I have seen are M2.5
cheers
conrad
Dale jordan
Been liked: 522 times
Post by Dale jordan »
Hello Conrad . I did the same thing to my KT .. Just buy a 2.5mm drill bit plus a M3 tape .. Scribe a centre line on the underside of the mantlet drill the 2.5 mm hole . I then drill a 3.5mm clearance hole only about half way through the hole , then tape the last half with the M3 tape then add your M3 crub screw . Dale
Conrad Sharp
Been liked: 2 times
So just to clarify, I drill the hole in the underside of the mantlet or on the turret under the mantlet? I know its probably simple but so am I lol
Does the grub screw just act as a sort of stanchion to push the mantlet away from the turret a bit?
cheers for being patient
Dale jordan
Hi Conrad .., I don't have my KT with me to take a photo maybe the other guys can post a photo . The grub screw stops the mantlet from sliding off centre ... Dale
Paul Morris
Hi Conrad.
The grub screw works in the same manner as the the ones you fitted into your torson bar sytem, all it has to do in this case is "nip" the rear of the gun tube as Dale says to stop it from slipping. So you are not drilling a hole in the turret but in the large casting that the gun tube slides into see Lerh's photo.
Cheers Paul. :wink: P.S. did you get my reply?
[/i]
01524 720977
Conrad Sharp
Been liked: 2 times
Thanks Guys, I understand now, I think if I had encountered this problem it would have made sense quicker lol. Just checked my emails Paul and my wife had read it so I didn't spot it in my crowded inbox, reading it now, thanks Paul.
