One of the few, my M2 Half Track.
Forum for discussion relating to the M2/M3 and M16 US Half Track
Neil Cousens
Post by Neil Cousens »
Has liked: 1419 times
Been liked: 1594 times
Clever idea with the petrol tanks Neil :D
Neil Cousens
Thanks Adrian. The wife and I had a look at it and came up with the idea. :idea:
I have been busy fitting the chequer plate, spraying and fitting in the wiring before joining the body to the chassis.
Mike Stannard (toyrific)
Post by Mike Stannard (toyrific) »
Hi Neil
Sorry about the wing nuts and damage deck plate, I did receive your e-mail about the wing nuts on 12.7.08, but as you seemed happy with them I did not respond.
Your mail. 12.7.08
Hi Mike, Just thought I would make you aware that 3 wing nuts, the thread hole is oversized so will not fit threaded stud. I can still use them by glueing them in place, so not a problem in this situation.
Thanks Neil UK
You purchased them on the tree and not cleaned and ready to use. I guess under the current circumstances of this post I should have followed up on this. All wing nuts have the thread cast in, but there are sometimes casting errors which effect the threads.
I have not received a e-mail from you about the deck plate being damaged, last mail from you was about which shipping company I used to send them on 5.10.10.
If you would let me know about the damage I will look into replacing them.
Really nice build on your Halftrack.
Mike
Neil Cousens
Brian Leach
Been liked: 3 times
Post by Brian Leach »
Neil,
Is that Tanaka out for s spin?
Brian
Brian
Neil Cousens
Hi Brian,
Yes, He was flying the flag, on our weekend BBQ.
Neil
Derek Attree
Has liked: 218 times
Been liked: 183 times
Post by Derek Attree »
Hi Neal
That is one cool half track.
Hope to see it at wings and wheels
Dan Williams
Been liked: 2 times
Re: One of the few, my M2 Half Track.
Post by Dan Williams »
Hi Neal,
I like your build job on the M2,when you put the road wheel tires on the road wheels,
did they fit? On mine all of them were too small, the inside diameter had to be open up by 10th.
And putting the tracks on by myself took much work.I tried to remove the idler wheel, and pull track back to line up center of wheel.But this was hard to do.
So was your's easier to put on?
I have not yet had the time to finish it.I also have to finish my Panther,I want to get some nice parts to finish it out.
Just wondering about other's built
Dan
Neil Cousens
Hi Dan.
PM sent.
Peter Silcock
Has liked: 60 times
Been liked: 33 times
Post by Peter Silcock »
Neil sent you a pm half track has ended up on Fylde coast ! Pete
