I want to use the spare sixth channel on my radio to turn the smoke unit
element on and off
to do this i was thinking of useing a servo with a micro switch attached
to it.
the question is , can i just conect the element to the switch or dose the
element have to be connected to a 24v relay and the switch turn the relay
on and off
thanks Dave Gray
smoke unit
- Been liked: 1 time
- Has liked: 1480 times
- Been liked: 1685 times
Richie mentioned an RC switch for turning the lights on and off which, if memory serves, had a relay already built in.
<later>
Found it - it's in this thread:
http://www.armortek.co.uk/forum/viewtopic.php?t=2017
<later>
- Paul Wills
- Has liked: 646 times
- Been liked: 143 times
Dave,
You can get the switch’s cheaper than that, they are about £11 for solderless ones on UK eBay.
http://cgi.ebay.co.uk/SOLDERLESS-Switch ... 747wt_1165
If you search through his other items you will find different types
Paul.
Paul.
Hi GUYS
Or you can use these, great amps aswell
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
richie(wiggytronics)
- Been liked: 177 times
Hi Guys
I have used the switch Richie shows in the Panther for a few years now. However, only for the convoy lights. It has worked very well. I know that doesn't answer yor original question Dave but thought I'd voice the positive experience with that particular switch. You can also buy it direct from www.robotmarketplace.com
I think that's it. They have all kinds of neat stuff and great service.
- Has liked: 2280 times
- Been liked: 7192 times
You would need to concider the amps that the element consumes, if say it requires 10 amps then you might concider using a 15 amp micro switch to be on the safe side, we use the servo/micro switch for most applications it keeps it simple and is relitivly cheap easy to adjust and you can add on more than one switch if you require ( using a snail or cam to engage the switch arms as it rotates) 15amp micro switches are around £6 per 10 on Evilbay , a standard servo will operate the switch with ease.
Or you could just buy the nice switcher that Wiggy has found, hope this helps
