Here are some photos of the finished hull width indicator lights and the rear light, they have been made so you can fit a bulb inside so the fronts are seperate, the front light stem has been drilled through for the wires and would require the bracket making, then the light will need to be glued on to the bracket the rear light has the two fixing holes pilot drilled and you will need to tap them to your prefered size of thread and make up the L shape bracket, pm me if your interested. cheers, clive.
