My KT photos
Paul Wills
Has liked: 646 times
Been liked: 143 times
Post by Paul Wills »
Hi Lerh Chang,
The tow cable I used is not the Armortek one, it's Mike Stannards. you have to look at the photos to get it in the right position though.
I have just measured the Armortek cable and Mike’s, and there isn’t any difference between the two!
Paul.
Chang
Has liked: 16579 times
Been liked: 487 times
Post by Chang »
Thanks for the advice Paul. Cheers. L Chang :D
Mike Stannard (toyrific)
Post by Mike Stannard (toyrific) »
The track tow cable real size is 15 meters, so a 6 scale one should be 2.5 meters (8 feet 2 inches), which mine are. However the cable I use to make them will not conform the same as the real cables, so you have to adjust the fittings accordingly. Explained in instructions that come with the tow cable set.
Mike
