detailing the inside
- Been liked: 2 times
Hi guys,
Adrian is right with his description of the locking lever and the visor being pivoted downwards to replace the glass block.
The spare glass is visible on the left side of the bottom picture, partly hidden behind the steering wheel
That is the way it is described in the book by Uwe Feist and Robert Johnson from which I have taken the pictures.
Adrian, you will be safe with your DAK vehicle. Both versions were present there. I have pictures proving that.
Ad
Ad
- Has liked: 20 times
- Been liked: 737 times
After a week I finally have a working visor for the drivers vision port, if I were an engineer I would have worked out all the angles and clearances, but I am not so it was trial and error, the hardest problem for me was to stop the top edge of the hinged visor from hitting the body and not allowing it to fully open, on the full size visor the hinged arms are kept in tension with springs, so as the visor opens the springs push the top edge out allowing enough clearance to open, so I applied this to mine and it works, it also locks shut, and you can open and replace the glass vision block, just 4 more to go
regards Jeff
regards Jeff
- Been liked: 1767 times
- Has liked: 8 times
- Been liked: 701 times
- Has liked: 4 times
- Has liked: 1490 times
- Been liked: 1697 times
- Been liked: 1 time
- Been liked: 11 times
- Has liked: 162 times
- Been liked: 849 times
- Been liked: 177 times
First I must thank all of you for the kind comments, this forum is one of my best building aids, when I feel that this is only a model, and why bother to much, along comes another bit of encouragement, and this gives you a kick start, and makes you try that bit harder, its like not letting your friends down; as to some of the questions, no not a jeweler Steve, I buy and sell antique weapons; Yves I am making this a static model, that is why I have so much room to play with
regards
Jeff
regards
Jeff
