Yves jagdpanther update
yves mouton
Been liked: 722 times
Re: Yves jagdpanther update
Post by yves mouton »
Hello,
Main gun fixt into the hull.
I did make a hinge to open the rooftop because i have a lot of electrical wires from the visors and animatronic.
So this makes a easy acces to the inside.
Gonna make a triangle spacer to put between the hinge so the roof can open a bit more.
Also fixt the rear plate.
Best regards Yves
yves mouton
Hello,
I did have to cut the engine a little bit down to fit above the batterie.
Best regards Yves
yves mouton
Hello,
Today i started on the camo ( not finisch yet ) need some weathering and German markings.
Best regards Yves
David Brady
Has liked: 206 times
Been liked: 825 times
Post by David Brady »
Hi Yves,
Looking really good, nice camo.
DB
yves mouton
Thanks David
Best regards Yves
yves mouton
Hello,
A little update, put the markings on en some weathering.
Best regards Yves
Chang
Has liked: 16462 times
Been liked: 485 times
Post by Chang »
Good works Yves.
Is that metal cylinder block for gun balance a stock one or your adding?
Lerh Chang
Been liked: 1747 times
That looks good Yves, nice result, regards simon.
yves mouton
Hello Chang,
The cylinder was standart in the kit for the gun balance.
Thanks Simon that you like my camo.
Best regards Yves
yves mouton
Hello,
Starting with the tools and detailing, later on comes a animatronic in.
Best regards Yves
Andre Meylan
Has liked: 801 times
Been liked: 362 times
Post by Andre Meylan »
Congratulations Yves,
Such a beauty you have built !!!
Cheers, Andre
Marco Peter
Has liked: 1517 times
Been liked: 797 times
Post by Marco Peter »
Somebody has been BUSY! :mrgreen:
'Konan', my Tiger 1 Mid
'Gunther', my Panther G
yves mouton
Hello,
Today i received my magnets 12mmx2mm
the cube magnets in the foto i got for free :)
I use a gel Loctite to glue them in the hub cabs. ( Chris Fry his modefication ) i use.
Best regards Yves
