Yves jagdpanther update
- Been liked: 741 times
Re: Yves jagdpanther update
Hello,
On monday i did collect the jagdpanther and all the optionpaks from the Armortek factory.
Today i open the 4 boxes.
Best regards Yves
Best regards Yves
Hello,
Started on the jagd.
Started with the easy things to get in the mood....
Smoker fixt
Did make two speaker plates for protection.
Painting the tracklinks with Tamiya gun metal
Now a big therapy session
Started also on the sprockets,
i change the bolts on the outer sprocket rings with bolts with a smaller hex head
and put thread in the holes.
That's all for the moment, tomorrow go the my job again
Best regards Yves
Smoker fixt
Best regards Yves
Hello,
a little update of what i have done these days.
Working on the rear hatch details
Best regards Yves
Best regards Yves
- Has liked: 1123 times
- Been liked: 990 times
Nice update
On the first pic in late tread, what are you doing with the mill? And why?
At the Jagdpanther roof.
Have a nice day
Robert T
Have a nice day
Robert T
Hello Robert
I mill out the hole a little bit more to move the grenade launcher with a servo,
I also make the scopes movable
Best regards Yves
Best regards Yves
Hello,
Change the grills mesh,
Started also on the wheels
Best regards Yves
Best regards Yves
Hello,
Here a little update.
Use mr surfacer 500 for the metal wheel look
Put some welds on the jagd with a special tool ( thanks to Chris )
Best regards Yves
Best regards Yves
Hello,
Did some work on the front mudguards.
Arrived some parts from Dave / Simon / Phil and waiting from parts from Mark.
Best regards Yves
Best regards Yves
Looking good Yves, did you find the exhaust extensions in the box, they were separately wrapped?
Hello Phil,
Yes a find them,is this for inside the tank the extensions?
Are these extensions for in the red tubes?
Best regards Yves
Best regards Yves
Yes they are, they connect the engine exhaust pipes to the muffler pipes that pass through the rear armour plate.
Hello,
Working on the suspension arms and torsionbars.
I mill down the 8mm M4 grubs so i can put the fixt torsionbars from the outside into the belly
of the jagd ( also easy take out for maintenance ) so i dont need to unscrew the grubs to take out the suspensionbars.
I did this modification on all my tanks.
Best regards Yves
Best regards Yves
