Help/advice setting up SD KFZ 9 famo audio option pack
All topics related to Armortek's Sound Option Pack
Roy Morton
Been liked: 39 times
Re: Help/advice setting up SD KFZ 9 famo audio option pack
Post by Roy Morton »
Thanks for everyone help and advice still no joy my son will be back tomorrow to have another go but thought i would post a few pictures to see if anyone can spot a mistake I am making.
Roy Morton
Just a few pics to seeing anyone can spot a problem.
yves mouton
Been liked: 741 times
Post by yves mouton »
Thanks Kian,
Thanks for the electric diagram,
i lookt at my famo and i did use the y-leads ( forgot that i did ) :)
Best regards Yves
Mark Heaps
Has liked: 270 times
Been liked: 327 times
Post by Mark Heaps »
Hello Roy,
From looking at your photos and following the wires, you have your modules connected as per silver box.
Please confirm you have silver box and not red box.
Also the audio module is not plug & play, but once you have it correctly connected you then have to teach it to respond to your transmitter to play the pre-programmed sounds,whether you are are using a 3-position switch or a rotary one.
Have you done that ?
At what stage are you experiencing problems ?
Mark Heaps
Also I see from the photo that the motion module has a 4-DIP switch. Could anyone provide me with info on what the different setting do ?
It could be enormously helpful to me in future fault-finding for you, and the solution may simply be switching one off & on because it failed to get electrical connetion the first time.
Shaun Hunt
Been liked: 10 times
Post by Shaun Hunt »
This is the setting for the Dip switches used on my Tiger 1
Set as per the photo in the Armortek instructions
Dip 1 up (setting for Radio m/s rate)
Dip 2 down (not active)
Dip 3 down (not active)
Dip 4 Up (Amp limiter for speed control 4 down is limited to 5A)
Hope this helps
dip switch settings
dip switch settings
Dip Switches.jpg (17.81 KiB) Viewed 2079 times
Roy Morton
Hi mark they are the silver boxes and a three way stick on the transmitter and when we turn on we have a loud click from speaker but no other sounds when we try to set up. Not sure the wires are in the right place.
Roy Morton
Just another thought is anyone close to me who could help. Dont mind a drive, I am in Derbyshire dronfield.
Has liked: 1475 times
Been liked: 1674 times
The wiring looks correct to me.
You are using the Gear channel for the sound selection. If you put a servo in that channel, does it respond as expected when you move the switch back and forth ?
Have you been through the sound teaching process with the Benedini board ?
When you power up, you should hear a thud from the speakers as the sound board powers up, then two clicks as it initialises:
Been liked: 3679 times
Hi Roy, When I spoke with your son the other day he was unsure of the connections - I showed him what pages to refer to in the manual.
What is the issue now - is something not working as expected or you are unsure of what connects where ?
If the latter then, using the manual, go through one RC lead at a time end to end and label them as you go. That should help.
Kian
Roy Morton
This is a video of what happens when trying to bench test. Every function works as it should. It I wired as per the silver box wiring diagram.
Are you operating two different switches to do the set up and when you say it will only play one sound ?
michael hilton
Has liked: 1566 times
Been liked: 836 times
Post by michael hilton »
Hello Roy, I am following your problem. I have a similar setup on my Panther ; see Mick's Panther A in the Panther section.
Is it worth re-programming the Audio Unit. You look to have all your connections in order. I have all my sounds activated before I run the Panther, I do not move the three way switch while moving the drive stick.
Adrian explained the Audio setup for my Panther A. If the Audio unit is programmed correctly, pressing the silver box ''on'' switch activates the sounds after your hear the ''clicks'' , you should not have to press any button on your Audio Unit.... Mick.
Roy Morton
Trying to follow section 5 bench test.
