Churchill Mk3 number 67
Forum for discussions relating to the Churchill
Gary Richardson
Has liked: 781 times
Been liked: 1853 times
Re: Churchill Mk3 number 67
Post by Gary Richardson »
Good morning
Just a photo showing the top coat being applied to the turret, this is a Mike Starmer mix of Tamiya acrylic paints to achieve the SCC15 used on the AVREs when upgraded before D-Day.
Gary
SCC15 Topcoat applied with a wide angled air brush
Gary Richardson
Hi all
I finished top coating the turret this morning and while I was on a roll decided to get the turret lid welds done. As usual it is done with Milliput with the welds imprinted in lines going along the seams as per full size. The electrical tape ensures there is a minimal gap and is easily removed once the Milliput has set by pulling from one end. The tape thins as it stretched and pops out. I also finished making one of the drivers hatch brackets that holds the hatch in the open position. I used a magnet on the underside of the deck and M2 steel bolt through the bracket bottom. This works really well and the hatch stays open even when I give the deck a good shake.
See you at the open day.
Gary
Lid held open with bracket and magnet
Turret lid welds
Turret lid welds
Gary Richardson
Good morning
A quick update regarding the turret welds. After letting the Milliput harden the tape was pulled until it stretched enough to come free. I did a little bit of trimming with a scalpel to ensure there was a slight gap between the welds and the turret roof.
The welds were red oxide primed and top coated. I am now working on completing all the hatch detailing but may have to wait until after Tiger day at the Tank Museum as I need a few more photos to confirm if the drivers rear hatch also had the curved lid latch like the one I made for the front section. I suspect it will have but it is difficult to see on the Mk4 example without hanging off the walkway :D .
Gary
P.S. Can anyone confirm if the cupola was welded to the turret top, the few photo close ups I have are not clear enough to see what type was used.
Top welds completed.
Has liked: 789 times
I'm not expert on the churchill but do these help:
http://mapleleafup.net/vehicles/cac/croc_06.html
http://tank-photographs.s3-website-eu-w ... ngton.html
They sort of look different from yours.
p.s. Now it dawned on me that you are doing a Mk3 and the ones i found are later variants. Sorry.
Will Roberts
Has liked: 8 times
Been liked: 29 times
Post by Will Roberts »
Hello Gary,
I have many photos of Mk III and Mk IV turrets and no evidence of any welds around the cupolas. My Bovington pictures are too large to upload here but if you want them send me a PM with your email address. I will see you at Tiger Day seeing as we are always bumping into each other.
Regards,
Will.
David Battson
Has liked: 119 times
Been liked: 258 times
Post by David Battson »
Hi Gary,
I'm no expert, but wasn't that hatch unit/cupola supposed to rotate ? so no welds, though some seem to have a close fitting outer ring welded to the roof to protect from bullet splash.
Gary Richardson
Hi all
Thanks for the replies concerning the cupola. Research is ongoing but I am leaning towards the cupola being able to rotate. Although I have some photos of the Mk4 on the cast turret I want to make sure about the cupola on the Mk3 welded turret as on the AVRE.
Thanks Will, I look forward to seeing your photos. David, a bullet guard makes sense, perhaps that's what I can see in the old photos.
Vince, no problem. even on the Mk3 turret it may have been altered in 1944 when the AVRE conversions took place.
Thin Leather:
I have found a company that can supply A4 size pieces of leather in various thicknesses and colours. I have ordered a sheet of 0.5mm thick tan coloured calf hide to use for the hatch head guards. I will post photos once it arrives and I have made a padded guard.
The company is Leather4Craft based in the UK.
Gary
Gary Richardson
Hi all
With the recent few days of warm dry weather I started putting the top coats on the tracks. I wanted a brown finish which will allow the metal to show through as the tracks wear. The paint is from Railmatch and is called Frame Dirt, I was talking to a friend of my who makes model railways and he mentions the paints saying the truck frames always end up with a dirty brown colouration. As British tank tracks tend to have a bronze brown colour to them I thought I would try it out. They also do a lighter brown which may have been better but nobody had any in stock.
I will add further layers to make them look used with plenty of mud effects.
I have not made much progress on the Churchill decks as the new Guide Dog puppy is taking up a lot of my time and I am also building a new pond...nothing to do with the Bailey Bridge release :wink: :D
Gary
First coat of Frame Dirt
Gary Richardson
Good morning all
The Churchill build is going slowly but I have made some progress on the battery and speaker positions. I have made up aluminium rails which use the existing pannier bolt holes to stay in place. The batteries and speakers will partially reside inside the panniers leaving a decent amount of space in the hull for the other modules. I will spray the bearers white so they are not so intrusive and the speaker plates will have Velcro strips at the rear with grommet mounted bolts and wing nuts for the centre fixings.
The batteries are held in place with threaded M4 rods and a bar at the top. This installation leave enough room for the turret turn motor and means the front hatches can be used for switches etc. I will add more photos once it is all painted and installed.
Gary
Battery bearers and speaker plates
Just needs painting and fixing in place
Steve McEvoy
Has liked: 11 times
Been liked: 121 times
Post by Steve McEvoy »
Coming along nicely Gary. Finished for Ruishton?
Gary Richardson
Steve McEvoy wrote:
Fri May 24, 2024 2:21 pm
Hi Steve
I will certainly have it running for Ruishton, I will not have it finished though. I am hoping to have the decks and turret fitted but doubt if the mortar will be ready as I have yet to start on that. The new guide dog puppy Avon is taking up a lot of my time and I have been building a pond while the weather has been good. The battery rails have now been top coated and test fitted. I am pleased with how much space it has created by using the area inside the panniers. I should be able to get the other modules between the speakers and batteries so I will start routing the wiring and switches today.
Gary
Gary Richardson
Hi all
After a couple of minor tweaks I have the power module situated between the speakers. I am using Velcro to hold it in place as this worked well on the Tiger and makes it easy to remove.
Just a couple of photos to show the progress so far. Next step is the audio module location which I want to place near the exhaust/rear deck hatches so I can access the volume switch.
Gary
Batteries and speakers fitted using aluminium rails.
Simple solution for retaining the batteries.
Steve McEvoy
Has liked: 11 times
Looking good mate, look forward to seeing it.
Gary Richardson
Good morning
After a short break I have cracked on with the module installations. Putting the batteries in the panniers has given enough space to allow me to use the front hatches for the derrick connections I will need later. The on/off switch and smoke switch will go under the exhaust deck hatches.
Still a bit to do as the main power lead from module A to the power module needs extending plus I will fit the FAS100 to monitor the battery conditions.
I have started the wiring loom for the lights which will be controlled via a 12v regulator and electronic switch from the receiver.
Gary
Electronics being installed
Gary Richardson
Hi all
While a await some XT60 connectors to arrive to extend the power to the drive module I decided to get the mid deck assembled. I am hoping to be able to place the on/off and smoker switch under one of the hatches. I checked some photos of the MK 3 AVRE at the Tank Museum and will use countersunk slotted 2.5mm screws instead of the button heads and hex bolts shown in the manual. This requires quite a few holes to be countersunk
in the mid deck plate. I used the stop on my mill to ensure the countersinks were all the same depth and the screws are flush with the deck. I will also be adding the four stays that keep the hatches open, they are held along the centre line of the deck and I have started to make one just to get an idea what will be required. I will try and get some decent photos when I go to Tankfest as the ones I have are lacking detail/partially obstructed.
The smokers have been bolted in place albeit using the edge holes so nearer to the tank sides than in the manual. I need to work out how to attach the tubing to the exhaust in such a way the mid deck can still be easily removed. Having had an oil spill in the Tiger, partly due to a tube working loose, I want to ensue the Churchill smoke system if completely sealed.
Gary
Countersinking the mid deck holes
2.5mm brass slotted countersunk screws
Stay prototype for mid deck hatches
