Tiger 1 sprockets
Posted: Sat Nov 04, 2023 9:20 am
by Jeff Hyder
Pair of Series 1 Tiger 1 sprockets with 15mm shaft holes. Needs re-machining to fit new type of shaft lock. £40.00.
Many thanks
Re: Tiger 1 sprockets
Posted: Sun Nov 05, 2023 9:40 am
by Dave Jackman
Hi, I am interested in the sprockets. Do you have a picture? Method of payment?
Regards,
Dave.
Posted: Tue Nov 07, 2023 2:46 pm
by Jeff Hyder
Hi Dave,
Sorry for the delay in getting back to you. Sadly I have no photos of the sprockets, however as mentioned on the thread they are from Armortek's first production. They are cast as one piece-there is no separate tooth rings, there is no cracks or damage and the nut detail holes are good but only drilled on the outside and the bore hole size of the sprocket is 15mm with Woodruff key slot.
Hope this helps,
Many thanks
Posted: Tue Nov 07, 2023 5:18 pm
by Dave Jackman
Thanks for the reply. You didn't mention the payment methods. Are the teeth in good condition?
Dave.
Posted: Tue Nov 07, 2023 8:12 pm
by Jeff Hyder
Hi Dave , PM sent.
