Tiger 1 sprockets
Jeff Hyder
Been liked: 3 times
Tiger 1 sprockets
Post by Jeff Hyder »
Pair of Series 1 Tiger 1 sprockets with 15mm shaft holes. Needs re-machining to fit new type of shaft lock. £40.00.
Many thanks
Dave Jackman
Re: Tiger 1 sprockets
Post by Dave Jackman »
Hi, I am interested in the sprockets. Do you have a picture? Method of payment?
Dave.
Jeff Hyder
Been liked: 3 times
Hi Dave,
Sorry for the delay in getting back to you. Sadly I have no photos of the sprockets, however as mentioned on the thread they are from Armortek's first production. They are cast as one piece-there is no separate tooth rings, there is no cracks or damage and the nut detail holes are good but only drilled on the outside and the bore hole size of the sprocket is 15mm with Woodruff key slot.
Hope this helps,
Many thanks
Dave Jackman
Thanks for the reply. You didn't mention the payment methods. Are the teeth in good condition?
Dave.
Jeff Hyder
Been liked: 3 times
Hi Dave , PM sent.
