help
Steve McEvoy
Has liked: 11 times
Been liked: 123 times
help
Post by Steve McEvoy »
Hi Guys, hoping someone may be able to help me with an issue on the sound on my pershing. All functions working fine and all sounds ok except I can't get the engine acceleration sounds on the left track, right track is no problem. I am using 2 stick control I did go through the teaching process and when I tried to do left track I can't get the engine sound to come off tickover. Not sure what I am doing wrong. Any help would be much appreciated before I tear the rest of my hair out. Thanks in advance. Steve.
Steve McEvoy
Has liked: 11 times
Re: help
Meant to say I'm using tarannis controller and receiver.
Has liked: 1481 times
Been liked: 1687 times
Re: help
Are you doing them at the same time or trying to do them separately ?
Hint: It will only work if you do them at the same time. You'll probably need D to help as it will take three hands :?
(Sorry I missed your call - out on a run so phone was on DND)
Steve McEvoy
Has liked: 11 times
Re: help
Cheers Adrian, will give it a try tomorrow.
Steve McEvoy
Has liked: 11 times
Re: help
All sorted, problem traced to a duff y lead. So everything working fine now. On to the weathering my least favourite part of any build.
