Front Deck Assy & Turret
- Has liked: 8 times
- Been liked: 7 times
Is there some valid reason why there are only 3 M4x60 hex bolts with spacers and wing nuts? There are at least 4 through-holes on the underside of the turret that line up with the 3 bolts in the lazy susan. It would seem that 4 connections between the lazy susan and the turret would make the whole assembly more stable and secure. What am I missing?
- Has liked: 264 times
- Been liked: 195 times
- Has liked: 48 times
- Been liked: 40 times
Re: Front Deck Assy & Turret
I found lining up the three holes to place the turret on difficult because of the weight of the turret. If there were four I think it would be a lot harder. I've done it seven or eight times so far and when it was just the casting it was easy. Now with all the parts on (I remove the canon) you have to be careful how/where you grab it and align the three holes with the screws which may be hard to see depending upon your angle of view (is it up on a lift or down on the ground).
Nick C.
- Been liked: 3698 times
There is no need for 4 fixings - the turret will not be going anywhere with 3. In addition, as Nick pointed out, trying to align 4 bolts is harder than 3.
- Has liked: 11 times
- Been liked: 123 times
l found when l did mine if you mark the single one it make lining up the turret easy, and l think if there were four then when you fit the mechanisms for recoil/barrel lift etc you would have a job to access the fourth one if you wanted to remove the turret for any reason. My churcill has 3 holding bolts and is really stable.
- Has liked: 28 times
- Been liked: 29 times
Yes that completed turret definitely won't go anywhere three bolts are more than acceptable.
Ok. I guess 3 is better than 4 or sufficient. With all the parts on the turret, it will be difficult at best to align the 3 bolts into the turret holes. I've watched Tony's video a number of times, and the turret magically appears on the tank. I'm guessing he has a helper or two. Thanks everyone (and Armortek) for your feedback.
