Brushless drive motor and new gearbox update
Posted: Wed Aug 16, 2023 6:33 am
I’v been looking for an alternative drive solution for some time now, various failures and damage steered me in different directions.
The AT gearboxes didn't work for me but many happy owners can't be wrong.
Working with another fellow member on here, who I won’t name but he is welcome to add his input if he feels like it.
We have been idea bashing and looking at different solutions to gearboxes that are robust and cost effective, on top of this we have also been working on a brushless motor idea.
Well it’s now at a stage where we are happy with the results.
First comes the gearbox a cheap industrial worm type gearbox that’s readily available, an adaptor was designed and made, this was then improved upon with the addition of a bearing close to the AT spur gear to support it Motors wise I think the AT motors can have an adaptor to be used on this type of gearbox, our first brushed motor for testing the gearbox was a 350w DC its what we ran at Tankfest and other events. This soon got changed to the out runner brushless motors we are now using.
So advantages so far:
Smaller compact design
Cheap industrial gearboxes that have different ratios available 7.5/10/15/20:1 meaning that different speed can easily be achieved.
Brushless motor size is smaller making more space for battery's etc.
Motors can be tuned to perfection and the controllers have an App
slow speed control of the motor is far superior
Torque at slow speed is very good. Reilly was embarrassed by trying to hold the tank back even at 5% throttle.
Disadvantages so far:
Cost to develop the idea
The gearbox I am using needs bolting in from the outside meaning the taper lock needs to be removed to gain access, hopefully not too many times. The next design may overcome that.
A change of electronics would be needed for brushless and larger power cables to the ESC recommended.
Would I do it again?
Yes, its the only option I would now choose. its not for the faint of heart and I nearly gave up at some points.
Did the tank get modified?
No alterations were made to the AT model in any way, this is a true bolt in option, didn't even drill any holes.
Big question how much did it cost?
Not any more than the other option
