Brushless drive motor and new gearbox update
Locked
Paul Sparkes
Has liked: 98 times
Been liked: 243 times
Post by Paul Sparkes »
I’v been looking for an alternative drive solution for some time now, various failures and damage steered me in different directions.
The AT gearboxes didn't work for me but many happy owners can't be wrong.
Working with another fellow member on here, who I won’t name but he is welcome to add his input if he feels like it.
We have been idea bashing and looking at different solutions to gearboxes that are robust and cost effective, on top of this we have also been working on a brushless motor idea.
Well it’s now at a stage where we are happy with the results.
First comes the gearbox a cheap industrial worm type gearbox that’s readily available, an adaptor was designed and made, this was then improved upon with the addition of a bearing close to the AT spur gear to support it
Motors wise I think the AT motors can have an adaptor to be used on this type of gearbox, our first brushed motor for testing the gearbox was a 350w DC its what we ran at Tankfest and other events.
This soon got changed to the out runner brushless motors we are now using.
So advantages so far:
Smaller compact design
Cheap industrial gearboxes that have different ratios available 7.5/10/15/20:1 meaning that different speed can easily be achieved.
Brushless motor size is smaller making more space for battery's etc.
Motors can be tuned to perfection and the controllers have an App
slow speed control of the motor is far superior
Torque at slow speed is very good. Reilly was embarrassed by trying to hold the tank back even at 5% throttle.
Disadvantages so far:
Cost to develop the idea
The gearbox I am using needs bolting in from the outside meaning the taper lock needs to be removed to gain access, hopefully not too many times. The next design may overcome that.
A change of electronics would be needed for brushless and larger power cables to the ESC recommended.
Would I do it again?
Yes, its the only option I would now choose. its not for the faint of heart and I nearly gave up at some points.
Did the tank get modified?
No alterations were made to the AT model in any way, this is a true bolt in option, didn't even drill any holes.
Big question how much did it cost?
Not any more than the other option
222 scout car
Has liked: 2282 times
Been liked: 7196 times
Re: Brushless drive motor and new gearbox update
Nice work guys, that brushless motor is very compact indeed! I've used other motor and gearbox options very often found on eBay without any problems at all, I've even used different size motors ( on the same vehicle ) with as close to the original gearboxes ratios as I could get and again no problem what so ever, I do tend to use 2 stick control as this lets your thumb unconsciously even out any small drive differences, whether that be mud, a stone, motor irregularity ect giving a smooth fully adjustable driving experience.
Markus Beer
Been liked: 55 times
Post by Markus Beer »
Hello Paul
Can you tell us what components (controller/motor/gearbox) you installed and where you sourced them?
Best thanks for your efforts
Markus
Paul Sparkes
Has liked: 98 times
Marcus,
I wish it was that easy.
All the mounts and shafts are custom made.
The motors have custom shafts to fit the gearboxes
The gearboxes are available on eBay,aliexpress and most bearing suppliers, but will need some alterations for our application.
This fits the KT and JT, also the Tigers but not sure which other tanks.
Then you have what speed do you require.
Esc can be hobby grade or expensive.
See what I mean 😪
222 scout car
Markus Beer
good morning Paul
thank you very much for the quick reply.
I will follow your progress with interest and will certainly get back to you.
best regards
Markus
Locked
