I have a question or two about the smoke module. Mine is on order so not in hand nor documentation.
What inputs does the smoker have? Heating % or on/off? Fan % or on/off?
What I hope to accomplish are the following:
1) At end of engine starting sound (or there-abouts) heavy smoke tapering down to very little in about 30 seconds. Seems the new smoker does this already? If so are the taper times and reduced level adjustable?
2) When "thr" stick leaves about 0% position heavy smoke, tapering to very little in 1 or 2 seconds. "very little" being adjustable.
3) Number one continues after a engine start with number two being added if motion is commanded before 30 second taper ends.
I have obtained my Transmitter Taranis x9D Plus SE. I will start fussing with openTX companion once I buy a new computer . My old apple's OS can no longer be updated and apparent the companion wont load on Os10X.
Thanks.
Smoke module control
- Has liked: 7 times
- Been liked: 77 times
1:6 King Tiger. 1:1 White M3A1 Scout car, Ford GPW, Dodge WC-57 Command Car, Ford GTB, CJV-35/U, Willys MB, Willys M38.
- Ed Groenenberg
- Has liked: 96 times
- Been liked: 628 times
Re: Smoke module control
Hello Mark.
The new smoker uses a heating element independently from the control.
When you switch on the heater and wait 30 - 45 seconds, and then 'start' the engine by moving
the trottle stick a little forward, the sond module will initiate the start engine sound, as well as
set the axial fan to max speed, thus generating a cloud of smoke.
Then, the fan speed will trottle down to a lower speed, matching an 'idle' running engine.
When you mobve the stick forwards / backwards, the sound will rev up, as will the fan.
When the sound unit will stop the engine, another puff of smoke should appear.
Thank you Ed. Seems like most of my "wants" are taken care of. I want to avoid continuous heavy smoke while driving along. These were not diesel powered vehicles.
