Manual for old black power supply module
Michael Röder
Has liked: 79 times
Been liked: 113 times
Post by Michael Röder »
Hello!
I'm looking for the instructions for the old black version of the power supply for my Panther from 2006
Black boxes with red button on the side.
I would appreciate any help, thanks in advance.
Regards Michael
Will Roberts
Has liked: 9 times
Been liked: 29 times
Re: Manual for old black power supply module
Post by Will Roberts »
Hi Michael,
I have a copy of the Panther G Option Pack 1 Assembly Instructions Release 1 14.12.06 which contains fairly simple instructions which I can scan and send you if you wish. It also contains an Electrical Schematic on the back page and a list of the Jumper settings in the module.
Will.
Has liked: 1495 times
Been liked: 1699 times
If you have a copy of the manual for the first range of silver modules, (Power Supply, Speed Control and Auxiliary), then the Power Supply Module contains the same PCB as the plastic black box with Armortek engraved in the top, so the manual is applicable to both.
Michael Röder
Has liked: 79 times
Hello Will, hello Adrian!
Thank you for your replies.
Good to know that the described black boxes use the same technology.
