M3 Washers….🙀🙈
Brian Womersley
Has liked: 33 times
Been liked: 28 times
M3 Washers….🙀🙈
Post by Brian Womersley »
Progressing quite well into my Pershing build…..
Sorting out all the hardware for next stage of build, came across a bag of M3 flat washers (164).. shock/horror… should I have put washers under ALL the M3 nuts I had already fitted….
Frantically checking all previous build pages could not find any reference to fitting washers under nuts.
Forward checked all remaining build pages and right on the last page that shows track construction found that each of the 82 ( X2) track sections has a pin/M3 washer and split pin.. so 82 times 2 = 164. ….. relief and panic over.. still on course here in the U.K. 🙏😁
(The bag of 164 washers is not listed on the fasteners page)
Tom Miller
Been liked: 347 times
Re: M3 Washers….🙀🙈
Post by Tom Miller »
Those are for the track pins. Last page of the manual.
Brian Ostlind
Has liked: 975 times
Been liked: 2068 times
Re: M3 Washers….🙀🙈
Post by Brian Ostlind »
That’s a sinking feeling. Always good to read the manual before you get started.
