Page 1 of 2
Motion and sounds packs
Posted: Sat Mar 18, 2023 5:59 pm
by Phil Woollard
She looks all fairlawn plonked in my tracked barrow ( the easiest way to move these big lumps around with a degenerative spine) I have to fit the motion and sounds packs only but still worth posting the progress as it happens.
Re: Motion and sounds packs
Posted: Sun Mar 19, 2023 2:02 pm
by Phil Dawe
That's you busy all summer Phil!
Posted: Sun Mar 19, 2023 3:05 pm
by Phil Woollard
Na shouldn't take long but I do have the running gear to sort out as well. I see the rear lights have be trashed in transit.
Posted: Wed Mar 29, 2023 6:43 pm
by Phil Woollard
Lots done. The body has been removed. There are some nice details on this model.
Posted: Fri Mar 31, 2023 3:38 pm
by Phil Woollard
I'm getting my teeth into her now and I am slowly finding the areas that need fetling, it's all very tight around those road wheels. It's worth noting that this model was built by its last owner as a "static" and build very well. Time in damp conditions has taken its toll.
Posted: Sat Apr 01, 2023 2:16 pm
by Phil Woollard
A little more done today.
Posted: Sat Apr 01, 2023 11:46 pm
by Phil Dawe
Phil, It looks like an engineering challenge fettling her up to get her into running order! But if anyone can do it, you can! :D
Posted: Wed Apr 05, 2023 6:13 pm
by Phil Woollard
Lots done this afternoon.
Posted: Tue Apr 11, 2023 6:16 pm
by Phil Woollard
She's now fighting me all the way but I'm winning.
Posted: Tue Apr 11, 2023 7:49 pm
by Mark Russell
Phil the outer diameter of the new style sprocket tyres needs be 123.5 to 124mm. The tracks will then sit correctly. I turned my glued tyres down in a lathe whilst on the sprockets.
Thanks,
Posted: Tue Apr 11, 2023 8:46 pm
by Phil Woollard
That makes perfect sense Mark thankyou! I shall now turn my lathe black with rubber dust.
Posted: Fri Apr 14, 2023 6:53 pm
by Phil Woollard
I followed Marks advice and the track fits almost perfectly with just a little fetling required.
Posted: Mon Apr 17, 2023 7:06 pm
by Phil Woollard
A taxing days work. It's fighting me all the way, everything interferes with its neighbour but I will methodically go through it , some of the tyres need reducing in diameter just a little to clear the hub of the adjacent wheel set, some of the rubber has a proud casting "rib" on one side which is rubbing the bobbin hubs .
Posted: Sat Apr 22, 2023 5:33 pm
by Phil Woollard
Lots done today.
Posted: Sun Apr 23, 2023 3:28 pm
by bryan massie
Very busy indeed Phil, she's coming on now :D
Bry.
