That feeling you get when you have a video of the exact moment you decide that I want one!!!
[media][/media]
I have taken this video back in 2006 at Leas Cliff Hall, Folkestone, England.
It was exactly here where I decided that one day when I am big, I want a Panther G.
After waiting another 16 years the time was right in 2022.
Receiving and checking all parts after delivery, and setting up a decent workspace I started building.
I decided to make a start on the wheels, as I noted some light surface rust that had to be contained and a small pressing imperfection that needed to be sanded down to ensure a flush fit of the rings and rims.
Panther G #22 of 2022
- Has liked: 38 times
- Been liked: 49 times
Re: Panther G #22 of 2022
I have added some flame cut marks and some fillets to better recess the weld beads that will be sculpted on later.
Quick question, has anyone tried to 3D print a raised fan case/heat exchanger to swop out the one on our tanks?
- 2584901_95c50f6ce9f3026d9f2ee6ec71de00f9.jpg (42.87 KiB) Viewed 3129 times
- _169_1-6-panther-g_126_4.jpg (61.16 KiB) Viewed 3129 times
What are you using to seal the lower hull corners from the inside? Saw this at the hardware store?
- Has liked: 252 times
- Been liked: 442 times
Hi Stephan,Stephan Joubert wrote: ↑Mon May 15, 2023 7:49 amWhat are you using to seal the lower hull corners from the inside? Saw this at the hardware store?
Nice to see the progress on you're build, is there any reason why you want to seal the lower hull.
Are going to be using it in adverse conditions?
To be honest you could fill with milliput/weld beads or I use P38 car body filler sets very hard easy to sand and quick drying, I would use it on the outside to make it easier to apply and sand however you could do it either way.
Gary
- William Gardeniers
- Has liked: 46 times
- Been liked: 282 times
Hi Stepfan
I used it, too seal my hull off the bergepanther.
With Regards William
